Trouble sending information from Octave to IoT Hub Azure
I have set up an Azure IoT Hub and would like to add a cloud connector from Octave directly to the IoT Hub. I am using the correct SharedAccessKey as indicated on this post: Having difficulty to use cloud connector to connect to Azure IoT Hub. I can receive data from the device on Octave, but can’t get the information streamed to Azure. The connector disables itself after one try, as in the original post. Could someone please advise what the problem could be ?
Have you declared your device in your IoT Hub and configured its IoT Hub device name in Octave as indicated here ? Pushing Events via Cloud Connectors
A.
