I am attempting to the the Third Party FOTA feature via AT+WDSTPF
In a network trace I see the module attempt to connect to a test HTTP server we setup for this however it then immediately stops downloading.
Via WDSI we see the following updates
WDSI = 9
WDSI = 18
WDSI = 11
Which seems to suggest and issue with the Flash but I have tried on multiple modules and they all show the same behavior so actuly HW issue in flash seems unlikely. Note, update via AirVantage does work.
Does anyone have Third Party FOTA command working? How should this work?
What file should be hosted on the http server? Right now I have and SPK file on there but there are not docs about this so this is an assumption.
For the package used in the third party FOTA, it is not using the spk file, it’s another kind of the FOTA package.
Please contact distributor to get the file.
