Hl7802 third-party FOTA
Hi all,
We are taking a Verizon certification and this time they asked us to perform a test with the Motive Bridge platform from Nokia. (We normally used AirVantage)
This is about connecting to their server for FOTA. So we have to make a third. I was following the instructions and then I had this
I checked Section 10. AVMS Commands in the AT commands reference and tried this
AT+WDSTPF=0,“coaps://ddocdpboot.do.motive.com:5684”
ERROR
then I tried this and I see it accepts HTTPS.
AT+WDSTPF=0,“https://ddocdpboot.do.motive.com:5684
So can I get the COAPS there? Am I thinking the right way?
Thank you
Hi @joao.bino,
If you want to do third party FOTA via https, you need to put that FW on https server and use AT+WDSTPF command.
For Verizon, it uses a different FOTA method and server is Nokia Motive server, it does not relate to the above command.
Please let me know how you would like to do it.
Hi @jerdung
Thank you for your reply. I need to do this: ( We need to configure for Verizon).
For Verizon, uses a different FOTA method and server is Nokia Motive server, it does not relate to the above command.
Do you have any guidelines? What should I do?
Hi @joao.bino,
In this case, it’s better you should contact to the nearest Sierra distributor for more detailed information as well as further instructions.
Thank you, I will get in touch with our distributors
