I looking for a basic solution to add a temperature sensor on a FX30 Octave.
Thank you
So there is a temperature sensor on the unit. Below is the terminal readout
root@fx30s:~# cm temp
Power Amplifier temperature: 16
Power Controller temperature: 16
root@fx30s:~#
And here is the AT command.
at!gstatus?
!GSTATUS:
Current Time: 200 Temperature: 16
Reset Counter: 1 Mode: ONLINE
System mode: CDMA PS state: Not attached
This was done on an FX30 LPWA.
Hi @romuald
Are you wanting to add an external temperature sensor? Does the interface matter to you?
The FX30 and FX30S can already support a sensor which outputs an analog voltage, such as the Analog Devices TMP36. The FX30S can also support a sensor with a Modbus interface.
Sensors with other interfaces, such as Dallas 1-wire or I2C are not natively supported by Octave. These would require building a custom application.
Ian
Hello Brian,
A CRC error is indicative of a noisy serial line or serial communications mismatch between server and host.
I would focus on the wiring if you are sure the serial config is good.
Here is a good link for troubleshooting.
