I need to set up an RV50 with the serial port configured as a TCP server.
In other words, in thre RV50 configuration I would expect to enter the port number for incoming (wireless-to-serial) packets, and the serial port parameters (115200,8N1), and not much else.
But on the serial port configuration, it seems that the destination ip address and port number must be entered. In server mode this should not be neccessary, since the outgoing traffic will be replies to the incoming (on wireless) traffic. Please advise, thanks.
Hi @norbert.payne,
I’m not sure if you’ve read the Configuration User Guide or not. Can you point out where in the Configuration User Guide what you mentioned is located so I can explain better.
