I have a client with 30 Lenovo Thinkpad X260s with EM7455s and after downloading SWI9X30C_02.24.05.06 from the Sierra Wireless website and opening the .exe file, it seems to work but after I check the firmware version it still shows the old version SWI9X30C_02.24.03.00.
Any ideas, are others seeing the same behavior or any idea how to fix the issue?
I’ve done the same for EM7455 on DELL E7270 running Windows 10 Pro 64 bit where result as below:
FDT version: 1.0.1702.1
Awaiting adapter …
Setting images preference …
Resetting …
Awaiting download port …
Downloading images …
Writing image -
Flashing image
Writing image |
Flashing image /
Enabling selective suspend …
Awaiting adapter …
Checking update status …
Firmware image download succeeded.
Final Firmware update succeeded.
Current:
Firmware:
ImageId: 002.021_000
BuildId: 02.24.03.00_GENERIC
Configuration:
Final images information:
Current:
Firmware:
ImageId: 002.026_000
BuildId: 02.24.05.06_GENERIC
Configuration:
OEM PRI: 9904802 001.001 Generic-Laptop
IMEI: XXXXXXXXXXXXXXX
Total time elapsed: 106891 ms.
Time to switch to boot mode: 14593 ms.
Images downloaded:
Image ID: ??
Build ID: 02.24.05.06?
write time: 4672 ms
additional flash time: 61156 ms
Image ID: 002.026_000
Build ID: 02.24.05.06_GENERIC
write time: 31 ms
additional flash time: 63 ms
Time to reset to application mode: 25187 ms.
Press Enter to continue …
I’m checking through HyperTerm and result as below:
Model: EM7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: XXXXXXXXXXXXXXXX
IMEI: XXXXXXXXXXXXXXXXXXXXX
IMEI SV: 12
FSN: LF618304770110
+GCAP: +CGSM
Does that firmware flashing finished completely ?
I solved my own issue, it turns out that Skylight Connection manager was not allowing the flash to take because I had SkyLight Connection manager set to automatically flash firmware.
