We recently started getting Fastrack Supremes and I have updated our software to run on them.
But in the process I bricked one of them
Normally on the old M1306Bs I would simply hold the boot pin to ground and use DWLWIN to restore it. The documentation says to hold the boot pin of 1.8V (rather than 2.8V) but this hasnāt worked either!
From my experience with Q24 and Q26 families I suggest you to try lower baudrate values with DWLWin, even if they are not supported by DWLWin interface (āRateā combo box at āSerial Port Settingsā section).
There is a DWLWin.ini file in DWLWin program directory. Open it with a text editor and change the āRateā parameterās value in ā[Download]ā section. This value will be used the next time you run DWLWin although it will not appear in the āRateā combo box as itās not a member of the combo box listā¦
It worked for me more than onceā¦ Hope it works for you tooā¦
