Specifying authentication method when using UDP
Is there a way I can specify PAP or CHAP authentication when using KCXNCFG +KUDPCFG and friends?
For some reason the KUDPCFG command hangs. We have tried may ways to get KUDPSND to work but none worked. All attempts seem to suggest that there are PDP Authentication errors ( as returned by manual PDP activation attempts). Our network operator tells us too that it does not work due to authentication failures at their radius server.
According to our understanding of the AT command guide, the following sequence should work.
Not part of this trace is that we successfully registered at the network (CREG=1; CGREG=1)
Sending: AT+CMEE=2
Sending: AT+CGDCONT?
Sending: AT+CGDCONT=1
Sending: AT+CGDCONT=1,“IP”,"",“0.0.0.0”,0,0
Sending: AT+KCNXCFG=1,“GPRS”,"","",""
Sending: AT+KUDPCFG=1,0
<< no reponse … ever >>
Can someone please suggest alternatives to try? Any help would be more than appreciated!
Mark
You can refer AT+WPPP command for PAP and CHAP authentication.
-Alex
