Hi
In the UK we have a lot of users who require PAP or CHAP authentication.
Is there a way to use the sample app to replicate the AT+CGAUTH / AT$QCPDPP commands?
Many thanks
John
Hi
Many thanks
John
Have you tried option 7 of SampleApps\lite-qmi-connection-manager ?
Please select one of the following options or press <Enter> to exit:
1. Start data session
2. Start Multiple PDN data session
3. Stop the currently active data session
4. Display all the profiles stored on the device
5. Display the settings for a particular profile stored on the device
6. Create a profile on the device
7. Modify the settings of an existing profile stored on the device
8. Delete a profile stored on the device
9. Enable QOS Event
10. Disable QOS Event
11. Request QOS Expaded
12. Get QOS Information
13. Get Packet Statistics
BTW, you might also send AT command via /dev/ttyUSB2 inside the application
Hi Jyi
Great answer - many thanks.
For anyone else trying this - the following is an example of configuring for the UK EE network using context 5 on an RC7602 module.
$ sudo ./lite-qmi-connection-managerrpi
lite-qmi-connection-manager v1.0.2108.1
Open transport "/dev/cdc-wdm0" in QMI mode
ModelID: RC7620
HomeNetwork: 3 UK
Network Selection Preference: auto
SessionStatus (0:ipv4): Disconnected
SessionStatus (1:ipv6): Disconnected
SessionStatus (2:ipv4): Disconnected
SessionStatus (3:ipv6): Disconnected
9. Scan available networks
10. Enable QOS Event
11. Disable QOS Event
12. Request QOS Expaded
13. Get QOS Information
14. QOS Indication Register
15. Get Packet Statistics
16. Get Current Channel Rate
Option : 7
ID PDPType IPAddress PrimaryDNS SecondaryDNS Auth ProfileName APNName UserName
1 0 0.0.0.0 0.0.0.0 0.0.0.0 0 eeb everywhere
5 0 0.0.0.0 0.0.0.0 0.0.0.0 0 three.co.uk
Please enter a profile id (1-42) (up to 2 Characters), or press <Enter> to exit: 5
Please enter PDP Type value( 0 - IPv4, 1 - PPP, 2 - IPV6, 3 - IPV4V6 ) (up to 1 Characters), or press <Enter> to exit: 0
Please enter IP Address in xxx.xxx.xxx.xxx format (up to 127 Characters), or press <Enter> to leave the field as blank:
Please enter PrimaryDNS Address Address in xxx.xxx.xxx.xxx format (up to 127 Characters), or press <Enter> to leave the field as blank:
Please enter SecondaryDNS Address Address in xxx.xxx.xxx.xxx format (up to 127 Characters), or press <Enter> to leave the field as blank:
Please enter Authentication value( 0 - None, 1 - PAP, 2 - CHAP, 3 - PAP/CHAP ) (up to 1 Characters), or press <Enter> to leave the field as blank: 1
Please enter Profile Name (up to 16 Characters), or press <Enter> to leave the field as blank: ee
Please enter APN Name (up to 103 Characters), or press <Enter> to leave the field as blank: everywhere
Please enter User Name (up to 128 Characters), or press <Enter> to leave the field as blank: eesecure
Please enter Password (up to 127 Characters), or press <Enter> to leave the field as blank: secure
Profile Settings updated successfully for Profile ID: 5
5 0 0.0.0.0 0.0.0.0 0.0.0.0 1 ee everywhere eesecure
After connection using $ sudo ./lite-qmi-connection-managerrpi
$ ifconfig
wwan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.103.253.129 netmask 255.255.255.252 destination 10.103.253.129
inet6 fe80::36b8:7f58:d3b:248c prefixlen 64 scopeid 0x20<link>
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 4 bytes 336 (336.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 8 bytes 528 (528.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
