I use an APN with authentication is mandatory for a connection 4G.
I make the following orders:
AT+CGATT=0 ==> OK
AT+CGDCONT=2,“IP”,“MyAPN” ==> OK
AT+WPPP=2,2,“logIn”,'psw" ==> OK but i think it’s useless
AT+CGATT=1 ==> OK
AT+CGACT=1,2 ==> +CME ERROR: 149 (PDP Authentification failure)
AT+CREG? ==> +CREG: 0,5 OK
AT+CSQ ==> +CSQ: 16,99 OK
AT+COPS? ==> +COPS: 0,0,“F SFR”,0 OK
In your forum, i found:
*For HL7692, if the uname and pword are mandatory for the APN “o#####b.##”", you should not use AT+WPPP=1,1,"##UNAME##","##PWORD##", because +WPPP does not work for the external PPP dial up app (ATD 99 *1#).
Please input the uname and pword in the external PPP dial up app.
I prepared pppd (Linux) with authentication, but:
ATD99**2# ==> NO CARRIER
if i use an APN without authentication, it works fine.
Version: RHL769x.2.27.183100.201809071813.x7120m_3|
Thank you for your help
