Currently I develop an application to send an email based on DOTA example, it works well when I tested it .
But when my customer try it with different SMTP server, they got this error:
I use SMTP authentication type WIP_SMTP_AUTH_NONE, does this makes the problem?
I have no idea with this error, does anybody know what’s the problem or maybe a/some documentation about it?
So, contact the Distributor to have Internet Protocol Feature activated is the only way?
Is there any other solution? update the firmware maybe?
I bought one Fastrack Supreme, but I could use it to send an email without this error.
I didn’t update or change anything. Mine and my client’s fastrack are the same: Fastrack version, firmware version,etc.
I have checked it with AT+CGMR and ATI3.
The different only that We got the modem from different Distributor.
So the difference is that one distributor sullpied a Fastrack with the feature enabled, and the other distributor supplied a Fastrack with the Feature disabled.
Again, this is why you need to discuss your requirements fully with your distributor to ensire that you get all the required features enabled!
