How to active the Internet Protocol Feature?
How to enable the plug-in Internet?
I am developing an application that sends data via FTP, but always get the following error message: FTP Error: Internet Protocol Feature not activated.
How can I enable this feature?
Already contacted my distributor but has not gave me any response.
I have great urgency to activate this plugin…
Your Distributor is the only route to activate this: it requires you to pay the appropriate fee, and then they will give you the necessary unlocking “key” code.
Lesson to learn: always be sure to discuss your full requirements in detail with any supplier before purchase!
I need to use FTP and HTTP protocols.
I think the only way to use the power is with the Internet Protocol asset I am right?
Got idea of how much the license of Internet Protocol?
No, it is not the only way at all. This has been explained to you before: it is entirely possible to implement these protocols from scratch - using just the basic TCP/IP from the Fastrack. But it doesn’t sound like you have the necessary skills and/or experience to do it yourself?
That would be for you to negotiate with your distributor.
Why do you need to use these protocols?
Have you considered just using a basic TCP/IP socket interface…?
I need that my modem send some data of 10 in 10 minutes for my server.
I can send via ftp or http GET.
I already tried the examples of WIPSoft and seems to work well only when I get the following error message: Internet Protocol Feature not activated.
What are the first steps to develop a script to do this by using only TCP / IP, there is a tutorial?
It’s not a script - it’s an Open-AT application.
Look at the “TCP Client” and/or “TCP Server” samples provided with WIP.
For a basic tutorial on IP sockets (not specific to Wavecom, WIP, or GPRS), see: viewtopic.php?f=16&t=1319&p=4836&hilit=+sockets+tutorial#p4836
Hello Everyone
I am trying to run the code for TCP/IP its test5. I am afraid I am unable to get it right in terms of what must appear on the terminal emulator. Embedded Application: Main appears on the TMT but what next I am even afraid to ask. If anyone knows this code may you please assist me.
I now have a detailed description of my problem.
  int r;
  TRACE (( 1, "Embedded Application : Main" ));
  /* Initialize the stack */
       r = wip_netInitOpts(
      WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_UART1, /* WIP traces on UART1 */
      WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_UART2,
      WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_TRACE,
      WIP_NET_OPT_END);
The application seems to hang after it prints the trace TRACE (( 1, “Embedded Application : Main” )); above. we recompiled with another trace just below the statement - r = wip_netInitOpts but it hanged again there. It does not seem to execute this statement properly and proceed with the program.
What could we be doing wrong??? :question:
