I have some problem with SL8090 AT-command always response OK.
but do nothing. I connect with USART1, 115Kbps, 4pin RX TX CTS RTS.
I can’t check even if Firmware version, SL8090 reponse only OK.
Do someone known this problem? and How can i get latest firmware version for SL8090?
Any suggestions welcome!
This is reponse from SL8090, AT command.
ATE1
AT+GMR
AT+GMM
AT+GSN
AT+CGMI
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,1,3975,710475
AT!GSTATUS?
AT+CFUN=1
AT+CMGF=1
AT+CMGL=“ALL”
AT!BAND=?
AT!GETBAND?
AT+CSQ
+CSQ: 16,99
AT+CREG?
AT+COPS?
+COPS: 0,0,“DTAC”,2
AT+CGMR
AT&V
AT+WIPCFG=1
AT+WIPBR=1,6
AT+WIPBR=2,6,11,“internet”
AT+WIPBR=2,6,0,""
AT+WIPBR=2,6,1,""
AT+WIPBR=4,6,0
AT+WIPCREATE=4,1,“183.90.170.8”,21,“test”,“test”
This is strange behaviour.
If you have any other SL8090, is the problem appearing in that also?
You can contact you FAE/ Distributor for the firmware packages.
please share the results with the new firmware.
Hi Rex_alex
Thank you for your help.
More progress, I connect this module to USB and every AT-command above work well. I still waiting for new firmware from FAE.
Surat
As far as I can recall there is a mapping command. Might be that the UART is not mapped to AT command port but to the modem port instead.
Modem port returns OK for most AT commands I’ve noticed.
(My testing of modem port was done with the USB-endpoint rather than UART directly)
In addition, I don’t think you can use WIP commands at all on SL8090 currently.
