Hi all,
I am using SL8082 GSM modem with micro-controller.
I am having problem with GSM registration, If i poll the status of registartion with CREG CMD i get response as (0,2) saying trying to connect, I polled for 5min but status is same.
If I issue the command CSQ for signal strength, response is : error: operation not allowed.
I tried with COPS = 1,2, 23415 // manual operator selection for Vodafone UK but this also does not works,
Hi awneil,
Thanks for the reply,
Problem was with my antenna connections. solved it.
now i am trying to connect my module to the GPRS network.
What is the sequence of Configuring or setting up the module for connection.
i am referring the supported commands & 3GPP 27007-630 specifications document.
can you suggest more document for this?
