SL6087 USB Interface
Dear all,
    I want to use the usb interface of SL6087 . But  I met some question.
    The host PC: Windows 7 64 bit .
    When I plug the usb connector to PC.Windows told me that "Unkown Device".it  have not install driver this time.and i check the hardward id. it is null.  i tested it under windows xp 32bit. it is same.
    the  SL6087 's firmware: 7.51.0.201205311751
    I have already check:
     1:VPAD_USB :3.3V .
     2:VBAT: 3.8V
     3: SL6087 works well by com port.
     4: USB port is enabled.
    Please tell me how can i check more.very thanks!
Have you tried installing the driver? It is available on
http://developer.sierrawireless.com
Not sure why you found hardware id is null… the default PID and VID should be:
idVendor: 0x114F
idProduct: 0x1234
However, it is configurable using +WUSB command.
For USB driver, it is available at
http://developer.sierrawireless.com/en/Resources/Resources/AirPrime/Tools/AirPrime%20-%20USB%20Driver%20Installer.aspx
It works with default PID and VID, you may need to modify it.
NULL hardware id is usually a sign that the communication is broken.
Might be the cable that is being used, might be faulty USB filter, or something else.
