I have a question about USB interface on SL6087 (firmware 7.45.1).
I have assembled the board with SL6087 and have connected USB to the SL6087 usb port as described in tech breef.
But i have no response from this usb. It looks like USB not working at all. Examples not working too. In examples USB init returns -1 when i try to initialize driver on SL6087.
How the normal usb connection have to behave usualy? Shal it register on PC when i connect USB cable? Or my be it shell open USB uart?
The host platform is Win7 64 bit and i use my own board. Now Win7 try to search for driver but then return error 43 (unknown driver).
I have check the USB and it is enabled.
I think i have problems with an hardware. It is possible that i have demaged the SL6087 inputs.
I also have a problem with USB in SL6087. I use my own board with embedded linux 2.6.21.
Software version is:R7.43.0.A1
SL is in default fast idle mode.
D- is always near 0 V
I don’t see SL6087 enumeration in system. I also can’t see any transfer on D+,D- pins. It seems like SL6087 is not detected.
I can enable USB with
AT+WMFM=0,1,3
D+ goes to 0,09 V
AT+WMFM=0,0,3
D+ shrinks to 0,01 V
Are those Values correct - D+ seems to low for me ?
How can I check if VPAD-USB is HIgh ? (How to read this input)
Are there any other AT commends to check USB state
Thank you for your answers,
Bartlomiej Grzeskowiak
