T_a
1
(used fw13)
root@swi-mdm9x28-wp:~# cm sim info
Type: EXTERNAL_SLOT_1
ICCID:
Home Network Operator:
EID:
IMSI:
Phone Number:
dmesg :
[ 30.443682] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its powered: msgs(n:1 cur:0 tx) bc(rx:0 tx:2) mode:FIFO slv_addr:0x71 MSTR_STS:0x091343c8 OPER:0x00000090
jyijyi
2
what is the return of the following AT commands?
AT!ENTERCND=“A710”
AT+CPIN?
AT!UIMS?
at+ccid
AT+CFUN?
jyijyi
4
then you can insert sim card
T_a
5
I already insert but it seem to not read how can I do??
jyijyi
6
probably the connection of the metal case or SIM case is not good, you can double check
