I have a MC7304 fitted in a M.2 socket with drivers installed. Its showing the following in log file:
ATQ0V1E0 - OK
AT+GMM - MC7304
AT+FCLASS=? - +FCLASS: (0-1)
AT#CLS=? - COMMAND NOT SUPPORTED
AT+GCI? - COMMAND NOT SUPPORTED
AT+GCI=? - COMMAND NOT SUPPORTED
ATI1 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7304
Revision: SWI9X15C_05.05.58.00 r27038 carmd-fwbuild1 2015/03/04 21:30:23
IMEI: xxxxxxxxxxxxxxx
IMEI SV: 18
FSN: J3838408480110
+GCAP: +CGSM,+DS,+ES
I have replaced IMEI number with x’s, shows valid number.
In Windows I get “Insert SIM”. Its connected to SIM2 connections on the M2 socket. The SIM worked fine in my phone. I have inserted it the right way round. I have thoroughly checked wiring is correct.
I have wires soldered on to the SIM card pins with scope probes attached and I see no activity at all not even sim power.
Is this a configuration issue? Any ideas what to try. Does it need to be on SIM1?
I have an unpopulated ESIM footprint on my board so shouldn’t see anything on SIM1.
Hi
I have a DM port on COM5, and NMEA on COM6.
I’ve seen data on COM6 at 9600, getting NMEA strings. Is it same settings on COM5? 9600 8bits 1 stop NONE NONE
There is also a WWAN Modem on COM7 cant get anything on COM5 or COM7. I’m using PuTTY.
Anything else I need to set up?
It looks like the SIM card is not being recognised. I’m also seeing no activity on SIM2 interface.
Can my schematics be checked by someone? I’ll need an email address to send it to.
No, our problem, the MC7304 does not support SIM2.
The design has been made for the MC7455 but production were struggling to get them, so a decision was made to use old stock of MC7304, the original module. It turns out the pins we are connecting to are NC pins, so no wonder it doesn’t work!
Thanks for the support you’ve provided, I think I have the answer!
