Showing "no echo" in HL7802 with firmware 4.6.8.0 and after updating firmware 4.6.9.4 showing "Error"
Showing “no echo” in HL7802 with firmware 4.6.8.0 and after updating firmware 4.6.9.4 showing “Error”
Turning modem on
Try saved baudrate: 1843200
üno echo
no echo
Try baudrate from the list: 1843200
no echo
no echo
no echo
no echo
Try baudrate from the list: 921600
no echo
no echo
Try baudrate from the list: 460800
no echo
no echo
Try baudrate from the list: 230400
x~þno echo
x~þno echo
Try baudrate from the list: 115200
ATE1
ERROR
Baudrate detected
Reading modem’s info
AT+KGSN=3
+KGSN: 52210231281510
AT+KGSN=0
+KGSN: 359459092879860
AT+CGMM
HL7802
AT+CGMI
Sierra Wireless
ATI3
HL7802.4.6.9.4
Manufacturer of modem: Sierra Wireless
Type of modem: HL7802
Modem firmware version: HL7802.4.6.9.4
Modem Baudrate: 1843200
Basic configuration of the modem
Turning modem off
my device is working fine with HL7692 and RC7620 but can’t understand why HL7802 is not working
Hi @mrinmoy ,
Welcome you to our community!
I tested your case on my HL7802 module with Firmware Release 4.6.9.4 and I didn’t observe the your issue. Please refer to the test log I attached below:
	14:09:20.182 on 21-Dec-2022> ati9
	14:09:23.193 on 21-Dec-2022>
	14:09:23.240 on 21-Dec-2022> HL7802.4.6.9
	14:09:23.240 on 21-Dec-2022> HL78xx.4.6.9.4.RK_02_01_02_00_137.20210615
	14:09:23.240 on 21-Dec-2022> 2021/06/15 21:00:02
	14:09:23.240 on 21-Dec-2022> IMEI-SV: 3594590900039214
	14:09:23.240 on 21-Dec-2022> Legato RTOS: 18.09.6.ALT1250.rc8 2021/05/18 20:22:09
	14:09:23.240 on 21-Dec-2022> atSwi: 44.01
	14:09:23.240 on 21-Dec-2022> UBOOT: 01.03
	14:09:23.240 on 21-Dec-2022> Apps: RKAPP_02_01_02_00_120__c2a0a2a6e5dd44ea4710b32fe98e69dc72bab7ce
	14:09:23.240 on 21-Dec-2022> MAC: ALT1250_02_01_02_00_123_2G
	14:09:23.240 on 21-Dec-2022> PHY: 12.50.265656
	14:09:23.240 on 21-Dec-2022> PMP: 277307
	14:09:23.240 on 21-Dec-2022> SBUB: 0
	14:09:23.240 on 21-Dec-2022> SBFW: 0
	14:09:23.240 on 21-Dec-2022> RPuK:
	14:09:23.240 on 21-Dec-2022> FPuK:
	14:09:23.240 on 21-Dec-2022> RBUB: 0
	14:09:23.240 on 21-Dec-2022> RBFW: 0
	14:09:23.240 on 21-Dec-2022> OK
	14:10:17.584 on 21-Dec-2022> at
	14:10:19.352 on 21-Dec-2022>
	14:10:19.352 on 21-Dec-2022> OK
	14:10:19.352 on 21-Dec-2022> at+ipr=230400
	14:11:59.469 on 21-Dec-2022>
	14:11:59.469 on 21-Dec-2022> OK
	14:12:22.506 on 21-Dec-2022> at
	14:12:23.730 on 21-Dec-2022>
	14:12:23.730 on 21-Dec-2022> OK
	14:12:23.730 on 21-Dec-2022> at+ipr?
	14:12:39.034 on 21-Dec-2022>
	14:12:39.034 on 21-Dec-2022> +IPR: 230400
	14:12:39.034 on 21-Dec-2022> OK
	14:12:39.034 on 21-Dec-2022> ate0
	14:12:51.885 on 21-Dec-2022>
	14:12:51.900 on 21-Dec-2022> OK
	14:12:53.541 on 21-Dec-2022> OK
	14:12:56.857 on 21-Dec-2022> OK
	14:12:56.857 on 21-Dec-2022> ate1
	14:13:03.045 on 21-Dec-2022>
	14:13:03.045 on 21-Dec-2022> OK
	14:13:03.045 on 21-Dec-2022> at
	14:13:07.977 on 21-Dec-2022>
	14:13:07.977 on 21-Dec-2022> OK
	14:13:07.977 on 21-Dec-2022> at+ipr=115200
	14:13:52.248 on 21-Dec-2022>
	14:13:52.248 on 21-Dec-2022> OK
	14:13:52.248 on 21-Dec-2022> at
	14:14:08.323 on 21-Dec-2022>
	14:14:08.323 on 21-Dec-2022> OK
	14:14:08.323 on 21-Dec-2022> ate1
	14:14:12.802 on 21-Dec-2022>
	14:14:12.802 on 21-Dec-2022> OK
	14:14:12.802 on 21-Dec-2022> ate0
	14:14:15.904 on 21-Dec-2022>
	14:14:15.919 on 21-Dec-2022> OK
	14:14:17.299 on 21-Dec-2022> OK
	14:14:21.690 on 21-Dec-2022> OK
	14:14:21.690 on 21-Dec-2022> ate1
	14:14:26.847 on 21-Dec-2022>
	14:14:26.847 on 21-Dec-2022> OK
With firmware 4.6.8.0, when typing ATE1 does the result return “OK”?
If yes, please save the configuration using AT&W command and then upgrade to firmware 4.6.9.4.
Then try again. Do the issue still happen in this case?
