HL7692 AT+IPR save baudrate value automatically to the non volatile memory
Hi!
I’d like to change the communication baud rate between my microcontroller and the modem HL7692. I read at the datasheet that is possible to change the baud rate and automatically save this value to modem memory.
I’m trying the following command:
AT+IPR=38400;W
and this not works, because at the next reset the modem baudrate continues to the default value.
any advice?
I don’t see problem:
ati3
RHL769x.2.24.173100.201709051100.x7120m_1
+SIM: 0
+KSUP: 2
ati9
HL7692
HL769x.2.24
x7120m
FUSED
2017-09-05 11:32:03
r10943
at+ipr?
+IPR: 115200
at+ipr=38400
üàü
//Here I change the baud rate to 38400
at
at&w
at+cfun=1,1
//after reset, the module works on UART baud rate 38400
ati3
Hi @rafael.dias,
Please try to use the command above with full parameters as
AT+IPR=38400;&W
It looks like the original command missed “&” character
hi @Vianney,
thank you for your response.
I tried your suggestion but this didn’t work for me.
Bellow I share my device output:
Turning modem on
Could not receive +KSUP: 0, try changing baudrate
Try saved baudrate: 1843200
+CGREG: 2
+WDSI: 0
+CGREG: 3
+CGREG: 5
+PBREADY
+SIM: 1
+KSUP: 0
ATE1no echo
ATE1
ATE1
ATE1
Baudrate detected
Reading modem’s info
AT+KGSN=3
+KGSN: VE820343691410
AT+KGSN=0
+KGSN: 355465070473828
AT+CGMM
HL7692
AT+CGMI
Sierra Wireless
ATI3
RHL769x.2.26.180400.201802141030.x7120m_1
Manufacturer of modem: Sierra Wireless
Type of modem: HL7692
Modem firmware version: RHL769x.2.26.180400.201802141030.x7120m_1
IMEI: 355465070473828
Serial number: VE820343691410
Entered bridge mode
ati3
ati9
HL7692
HL769x.2.26
x7120m
FUSED
2018-02-14 12:02:13
r12309
at+ipr?
+IPR: 1843200
AT+IPR=38400;&W
Turning modem off
USER: \ MAIN MENU
(1) SYSTEM
(2) CONTROL UNIT
(3) MODEM
(4) FLASH
(5) CAMERA
(6) CAMERA FOCUS
08/12/2020 00:03:34 >> Chosen function: MODEM
USER: \ MAIN MENU \ MODEM
(1) MODEM SETTINGS
(2) SEND PHOTO
(3) SEND STATION DATA
(4) GET GPS
(5) GET CONF SMS
(6) Download FW
(7) Download APN list
(8) Server redirection
(9) Modem FOTA
(ESC) BACK
08/12/2020 00:03:35 >> Select…no echo
08/12/2020 00:03:40 >> Chosen function: MODEM SETTINGS
no echo
Starting modem process
Turning modem on
+CGREG: 2
+WDSI: 0
+CGREG: 5
+PBREADY
+SIM: 1
+KSUP: 0
+CGREG: 3
+CGREG: 5
ATEno echo
ATE1
ATE1
ATE1
Baudrate detected
Just for sanity check, I tried the same sequence with a HL8548-G and it works as I expected:
Turning modem on
+WDSI: 0
+KSUP: 0
+PBREADY
+CGREG: 5
+GPSEVINIT: 1
ATE1no echo
ATE1
ATE1
ATE1
Baudrate detected
AT+KGSN=3
+KGSN: ZJ829200490310
AT+KGSN=0
+KGSN: 359516051363416
AT+CGMM
HL8548-G
AT+CGMI
Sierra Wireless
ATI3
RHL85xx.5.5.24.2.201710111800.x6250_2
Type of modem: HL8548-G
Modem firmware version: RHL85xx.5.5.24.2.201710111800.x6250_2
IMEI: 359516051363416
Serial number: ZJ829200490310
Entered bridge mode
ati3
ati9
2017/10/11 18:38:28
r6260
at+ipr?
+IPR: 1843200
at+ipr=38400
Turning modem off
USER: \ MAIN MENU
(1) SYSTEM
(2) CONTROL UNIT
(3) MODEM
(4) FLASH
(5) CAMERA
(6) CAMERA FOCUS
08/12/2020 00:23:24 >> Select…no echo
08/12/2020 00:23:26 >> Chosen function: MODEM
(1) MODEM SETTINGS
(2) SEND PHOTO
(4) GET GPS
(5) GET CONF SMS
(6) Download FW
(9) Modem FOTA
(ESC) BACK
08/12/2020 00:23:28 >> Chosen function: MODEM SETTINGS
Turning modem on
no echo
no echo
Try baudrate from the list: 1843200
no echo
no echo
Try baudrate from the list: 921600
no echo
no echo
Try baudrate from the list: 460800
no echo
no echo
Try baudrate from the list: 230400
no echo
no echo
Try baudrate from the list: 115200
àüno echo
àüno echo
Try baudrate from the list: 57600
ÄØüno echo
ÄØüno echo
Try baudrate from the list: 38400
ATE1
ATE1
ATE1
Baudrate detected
Configuring modem to saved baudrate
AT+IPR=1843200
AT&W
AT+KGSN=3
AT+KGSN=0
AT+CGMM
HL8548-G
AT+CGMI
Sierra Wireless
ATI3
Modem Baudrate: 1843200
Reading SIM’s info
ATE1
ATE1
ATE1
AT+CPIN?
+CPIN: READY
AT+CIMI
901405100001362
AT+CCID
+CCID: 89882806660000013625
AT+CPIN?
+CPIN: READY
AT+CNUM
SIM’s MCC: 901
SIM’s MNC: 40
SIM’s CCID: 89882806660000013625
SIM’s CIMI: 901405100001362
SIM’s PIN: READY
Basic configuration of the modem
ATE1
ATE1
ATE1
AT+CPIN?
+CPIN: READY
ATE1
ATE1
ATE1
ATZ
AT+KSLEEP=2
AT&D0
AT&K3
AT+CPMS=“ME”,“ME”,“ME”
+CPMS: 4,4,4,4,4,4
AT+CMGF=1
AT+CMEE=1
AT+KSREP=1
AT+KAAT=1
AT+KGSMAD?
+KGSMAD: 0,1,120,5,7
AT+CGREG=1
AT+CNMI=2,1,0,0,0
AT+COPS=3,2
AT+COPS?
+COPS: 0,2,“23203”,2
AT+WDSI=1023
AT&W
AT+CGDCONT=1,“IPV4V6”,“”
AT+CFUN=1,1
Waiting for complete initialization of the modem (+PBREADY)
+WDSI: 0
+KSUP: 0
+PBREADY
(1) GET MODEM INFO
(2) SEND IDENTIFICATION SMS
(3) UNLOCK SIM CARD (PIN CODE)
(4) SIGNAL QUALITY GRAPH
(5) APN OF CUSTOMER
(6) DELETE ALL SMS
(A) Check available APNs
(ESC) BACK
08/12/2020 00:27:07 >> Select…
how about changing to baud rate 38400 and then type AT&W ?
@jyijyi , this do not work for me.
This modem is in my equipment and the communication between my terminal and the modem is managed by a microcontroller with fixed baudrate. When I change the baudrate value, the microcontroller is not able to communicate with the modem.
Then that is your mcu problem.
Once you changed baud rate of module, you need to change baud rate of mcu together
So, we can conclude that we can not use multiple commands with one line when are using the IPR command.
Now it works on your side?
It is not working. .
No idea as i don’t see problem on my side if separating the AT&W into next command, I still suspect this is your MCU problem.
Maybe you can try latest fw
