I have a RV50x running the latest available ALEOS and Radio Firmware.
ALEOS Software Version: 4.15.3
ALEOS Build number: 003
|Device Model:|RV50X|
|Radio Module Type:|MC7455|Radio Module Identifier:|VERIZON|
|Radio Firmware Version: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30|
See attached image showing these versions:
I am unable to get Port Forwarding to function.
I have a device on the LAN at http://192.168.1.100 which has a web server running on port 80. When my laptop is connected to the LAN I can access the website so I know this device is accessible when I am on the same network.
The device at 192.168.1.100 has a statically assigned IP.
My DHCP range supplied by the RV50X starts at 192.168.1.125.
I have the following Port Forwards enabled:
I tried setting the Stop Port Number to match the Start Port Number and also set the Stop Port Number to 0, but this did not make a difference.
I do have Inbound IP restrictions enabled as shown below as I don’t want just anyone connecting
Even with these IP restrictions removed I am unable to connect to any of the ports I have setup in the Port Forwarding screen.
Is this a bug with this model/firmware?
Are there other settings I need to enable to allow the Port Forwarding setting to function?
Is there any logging or configuration I can supply to help diagnose this problem?
Thanks!
