Hi guy
Can anybody tell me what going on ? router will not put internet out from ethernet port to our machine. See log below
Dec 9 11:03:21 debug SWI0 SDK Process: psrwds_setipfamily: instance: 0 IP family: V4 Active WDS Client: V4
Dec 9 11:03:21 debug SWI0 SDK Process: psrwds_getsettings:
Dec 9 11:03:21 notice ALEOS_CELL_RadioTask: Connected IPv4; IPv4: 100.82.229.35 DNS1: 194.19.194.192 DNS2: 194.19.128.132
Dec 9 11:03:21 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_DISCOVERY
Dec 9 11:03:21 notice ALEOS_LINKMGMT_linkstatd: wwan0 is now up
Dec 9 11:03:21 info udhcpc[1357]: started, v1.35.0
Dec 9 11:03:21 info udhcpc[1357]: broadcasting discover
Dec 9 11:03:21 info udhcpc[1357]: broadcasting select for 100.82.229.35, server 100.82.229.36
Dec 9 11:03:21 info udhcpc[1357]: lease of 100.82.229.35 obtained from 100.82.229.36, lease time 7200
Dec 9 11:03:21 notice ALEOS_LINKMGMT_linkmon: Radio Connection State - Connected
Dec 9 11:03:21 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_CONNECTED
Dec 9 11:03:21 notice ALEOS_CONNECTMGMT_CMAN: scheduleIPV4StatusChange: Restart firewall
Dec 9 11:03:21 notice ALEOS_CELL_RadioTask: Value “name” read from XML file using iccid: ‘Unknown’
Dec 9 11:03:21 notice ALEOS_CELL_RadioTask: Value “name” read from XML file using mcnc: ‘Telia Danmark’
Dec 9 11:03:21 notice ALEOS_CELL_RadioTask: Operator : Telia Danmark
Dec 9 11:03:22 notice ALEOS_SECURITY_Firewall: Stopping firewall
Dec 9 11:03:22 notice ALEOS_SECURITY_Firewall: Applying IPv4 firewall configuration
Dec 9 11:03:22 notice ALEOS_SECURITY_Firewall: Successfully applied firewall configuration
Dec 9 11:03:22 notice ALEOS_SECURITY_Firewall: Starting firewall
Dec 9 11:03:22 notice ALEOS_SECURITY_Firewall: Initializing firewall tables
Dec 9 11:03:22 notice ALEOS_SECURITY_Firewall: DMZ State: Disabled, DMZ IP: 0.0.0.0
Dec 9 11:03:22 notice ALEOS_SECURITY_Firewall: Applying IPv6 firewall configuration
Dec 9 11:03:22 notice ALEOS_SECURITY_firewallManager: Firewall completed restart after 895 ms
Dec 9 11:03:22 notice ALEOS_CONNECTMGMT: *** Network Connection successful. WAN IP [Cellular] : 100.82.229.35
Dec 9 11:03:22 notice ALEOS_CONNECTMGMT: *** IP UP 100.82.229.35 : wwan0
Dec 9 11:03:23 notice ALEOS_CONNECTMGMT: GDNS is restarting dnsmasq
Dec 9 11:03:23 info dnsmasq[954]: exiting on receipt of SIGTERM
Dec 9 11:03:24 notice ALEOS_LAN: MTU Source Auto - Set DHCP option 26 MTU: 1500
Dec 9 11:03:24 err ALEOS_LAN: MTU Source Auto - Ignore Opt 26 MTU size 1500
Dec 9 11:03:25 notice ALEOS_LAN: Starting dnsmasq
Dec 9 11:03:25 info dnsmasq[1417]: started, version 2.84rc2 cachesize 150
Dec 9 11:03:25 info dnsmasq[1417]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth no-cryptohash no-DNSSEC loop-detect inotify dumpfile
Dec 9 11:03:25 info dnsmasq-dhcp[1417]: DHCP, IP range 192.168.14.100 – 192.168.14.100, lease time 1d
Dec 9 11:03:25 info dnsmasq-dhcp[1417]: DHCP, IP range 192.168.13.100 – 192.168.13.150, lease time 1d
Dec 9 11:03:25 info dnsmasq[1417]: reading /etc/resolv.conf
Dec 9 11:03:25 warning dnsmasq[1417]: ignoring nameserver 127.0.0.1 - local interface
Dec 9 11:03:25 info dnsmasq[1417]: using nameserver 194.19.194.192#53
Dec 9 11:03:25 info dnsmasq[1417]: using nameserver 194.19.128.132#53
Dec 9 11:03:25 info dnsmasq[1417]: read /etc/hosts - 1 addresses
Dec 9 11:03:25 info dnsmasq[1417]: read /etc/dnsmasq.hosts - 2 addresses
Dec 9 11:03:28 notice ALEOS_LINKMGMT_linkmon: New Link Status - Network Ready - Cellular
Dec 9 11:03:28 warning ALEOS_SERIAL_HMC: not in tcp mode current mode 0
Dec 9 11:03:34 warning ALEOS_ALMS_LWM2M: discard older handshake message with seq: 0
Dec 9 11:03:35 err ALEOS_ALMS_LWM2M: COAP_BAD_REQUEST
Dec 9 11:03:35 warning ALEOS_ALMS_LWM2M: Failed bootstrap, retrying in ‘10’ seconds, ‘4’ left
Dec 9 11:03:38 notice ALEOS_WEB_ACEmanager: User [user] login successful from IP [192.168.13.31]
Dec 9 11:03:53 warning ALEOS_ALMS_LWM2M: discard older handshake message with seq: 0
Dec 9 11:03:54 err ALEOS_ALMS_LWM2M: COAP_BAD_REQUEST
Dec 9 11:03:54 warning ALEOS_ALMS_LWM2M: Failed bootstrap, retrying in ‘20’ seconds, ‘3’ left
Dec 9 11:04:20 notice ALEOS_SECURITY_GAR: There has been a change in the filesystem since last checksums check
Dec 9 11:04:22 warning ALEOS_ALMS_LWM2M: discard older handshake message with seq: 0
Dec 9 11:04:23 err ALEOS_ALMS_LWM2M: COAP_BAD_REQUEST
Dec 9 11:04:23 warning ALEOS_ALMS_LWM2M: Failed bootstrap, retrying in ‘40’ seconds, ‘2’ left
Dec 9 11:04:35 notice ALEOS_LINKMGMT_linkstatd: eth0 is now up
Dec 9 11:05:11 warning ALEOS_ALMS_LWM2M: discard older handshake message with seq: 0
Dec 9 11:05:11 err ALEOS_ALMS_LWM2M: COAP_BAD_REQUEST
Dec 9 11:05:11 warning ALEOS_ALMS_LWM2M: Failed bootstrap, retrying in ‘80’ seconds, ‘1’ left
Dec 9 11:06:40 warning ALEOS_ALMS_LWM2M: discard older handshake message with seq: 0
Dec 9 11:06:41 err ALEOS_ALMS_LWM2M: COAP_BAD_REQUEST
Dec 9 11:06:41 warning ALEOS_ALMS_LWM2M: Failed bootstrap, retrying in ‘160’ seconds, ‘0’ left
Dec 9 11:07:36 notice ALEOS_LINKMGMT_linkstatd: eth0 is now down
Dec 9 11:07:37 notice ALEOS_LINKMGMT_linkstatd: eth0 is now up
Dec 9 11:07:44 notice ALEOS_LINKMGMT_linkstatd: usb0 is now down
Dec 9 11:07:44 info dnsmasq-dhcp[1417]: DHCPRELEASE(usb0) 192.168.14.100 4a:74:43:3c:76:b1
Dec 9 11:07:44 notice ALEOS_LINKMGMT_linkstatd: usb0 is now up
Dec 9 11:07:46 info dnsmasq-dhcp[1417]: DHCPREQUEST(usb0) 192.168.14.100 4a:74:43:3c:76:b1
Dec 9 11:07:46 warning dnsmasq-dhcp[1417]: Ignoring domain freya.local for DHCP host name ZDK-WN-20058
Dec 9 11:07:46 info dnsmasq-dhcp[1417]: DHCPACK(usb0) 192.168.14.100 4a:74:43:3c:76:b1 ZDK-WN-20058
Dec 9 11:09:29 warning ALEOS_ALMS_LWM2M: discard older handshake message with seq: 0
Dec 9 11:09:30 err ALEOS_ALMS_LWM2M: COAP_BAD_REQUEST
Dec 9 11:09:30 warning ALEOS_ALMS_LWM2M: Failed bootstrap, nothing left to do
Dec 9 11:13:39 notice ALEOS_LINKMGMT_linkstatd: eth0 is now down
