I have a RV50x device and have configured a dyndns account to enable remote access.
After the device boots I can see the IP address being updated on dyndns by the gateway but the IP address it sets is not the WAN Cellular IP.
I’m unable to access the device at all through this other IP and I’m not sure what adapter it referrs to.
Is anyone able to advise how to ensure the dynamic dns IP uses the cellular WAN address?
Hi ashby.martin,
Please ensure that you can remote access through WAN IP address. If you can’t access, you can not access using dns domain.
You can check dynDNS function with Sierra server for free. Try to configure “IP Manager” in dynDNS service.
-> Enter device name example: RV50test, domain = eairlink.com; IP Manager Server 1 = edns1.eairlink.com
-> Reboot
To check, you can ping your RV50 WAN IP, and then ping to RV50test.eairlink.com (if it routes to WAN IP, so you can access to web page using this domain)
If you use third party dns such as
dyndns.org, make sure that your domain is correct
To revive an old thread, does anyone have specific experience with using dyn.com (formerly dyndns.org)? What server names should be input into Ace Manager to make it work?
Thanks!
JBA
Hi @jbanders
Because Sierra Wireless will discontinue free IP Manager Dynamic DNS Service (hosted at eairlink.com) effective July 1, 2023. So I suggest you to configure an alternate commercial dynamic DNS service. For more detail, please refer to page 1 in the document below:
https://source.sierrawireless.com/resources/airlink/software_reference_docs/release-notes/aleos-4,-d-,16,-d-,0-release-notes/#sthash.tBKRxsLD.dpbs
