It is my first time implementing an RV50X, during I encounter a strange issue where the device has decent connection:
AT Signal Strength (RSSI) -51
AT LTE Signal Strength (RSRP) -76
AT LTE Signal Quality (RSRQ) -7
AT LTE Signal Interference (SINR) 30.0
Welcome to our community!
To narrow down the issue, could you please answer the questions below:
Please ensure that antennas are properly attached to RV50X. Two antennas are required when connecting to an LTE network.
Please try using a different SIM that’s working fine to see if the issue still happens.
Please get the log and template log by the instructions and send me:
The configuration template file is in ACEmanager → Template, provide any name you desire for the Template Name, and then press Download to retrieve the template file.
Based on the log file you provided, I notice several lines showing:
Sep 17 07:13:17 notice ALEOS_CELL_RadioDiagnostic: Radio is in Low Power Mode. The LPM voters are: W_DISABLE
The radio module is in Low Power Mode because the W_DISABLE pin is asserted.
From the user side, that pin (W_DISABLE) is inside the RV50X router and I could not find any instructions in either the hardware guide or the software user guide on how to interact with that pin, so this is very likely a hardware issue.
Could you please let me know how many units you are experiencing this issue on?
In this case, it would be best for you to proceed with an RMA. Please refer to the following link: https://customercommunity.sierrawireless.com/s/repair-case
