RV50 Trusted IP range inverted
I’ve inadvertently entered what is likely an invalid range for my trusted IP range on an RV50x running firmware 4.13.
The Range Start value is a valid IP address for a trusted “friend” and I have verified this IP is the one I am using to attempt to connect to the modem. However, the Range End IP address is less than the start address.
Range Start: xxx.xxx.235.xxx
Range End: xxx.xxx.234.xxx
Should this system still respond to pings if I am attempting to connect from the Range Start IP address or I have I created additional problems by entering an invalid Range End address?
Hi @natef,
You still can respond to pings and connect from Range Start’s IP address on RV50X firmware 4.13.0.
Please help to mark “Solution” if your question is answered.
