I recently updated my firmware on the RV50 with the latest update and now my ptz camera will not connect with the router. The router shows it was a strong signal but no connection. Any ideas?
I assume you have PTZ plugged directly into the RV50 via ethernet?
I suspect you are having DMZ issue as the latest firmware disables the DMZ by default now.
Try going to Security & Port Forwarding
Set the following:
DMZ Host: Automatic
That’s what the problem was! We figured it out earlier but I greatly appreciate the response.
