GOOD DAY!
I have a problem with Hello-word test,
according to instruction “Tutorial” in OpenAt.
After Success prompt in HyperTerminal
Hello World from Open-AT
the next test is unsuccess.
I use OpenAt version 3.10,
modem program has the same version.
modem WAVECOM FASTRACK WISMO.
on ATI3
Response
655_09gg.Q2406B 2015268 111705 17:01
on AT+WOPEN=3 AND AT+WOPEN=4
Response ERROR
Help me, please.
Hi RUBINS
you do not give enough unfo to mae full analysis
use AT+WOPEN=2 to see if there is an application on the modem first
if it returns V3.10 V3.10 then there is an application on the modem then you must fist stop it with AT+WOPEN=0 and the only can you do the wopen=3 and 4 to delete it
if you get ERROR then it might only mean that there is no application to delete
if you use AT+CMEE=1 then it will not give you only ERROR but also the error code which you can look up in the AT commands Appendix to determine why you get the error
It does not sound that you got to the part where you load the app one modem.
But if you loaded the app into the modem and it does not work after the AT+WOPEN=1 then your parameters might be corrupted.
Use x-modem(in hyperterminal) to load the file “655_w.dwl” into your modem to reset the default params.
you can find this file in “C:\OpenAT\Tools\CoreSW\655\OtherCountries”
I hope this info helps.
Walter
