OpenAT I need help!! M1306B dont accept AT cmds
the baud rate of the modem is 9600 like the configuration of hyporterm
i had no problem at this.
I uploaded a hello world open at application, that aparently was nothing hard.
adl_atSendResponse ( ADL_AT_UNS, “\r\nHello World from Open-AT\r\n” );
i used the gcc compiler, and without any link
I used hyperterm and
AT+WDWL
i uploaded the gcc_Hello_World.wpb.dwl that was in the out folder of my Open At first Project.
then when was completed and automatically closed the window
i did the reset, everything worked perfect at this point.
§§§§§§§§§§§§§§§§§§§§AT+CFUN=1
then I…
AT+WOPEN=2 to run the app
and then in theory should say Hello World from Open-AT every 10 seconds,
insted keeps saying
every 10 secs.
I readed a lot what went wrong, and aparently the TRACE function every 10 secs is working, but cant show it in hyperterm because of the IPR i setted to 9600 and it has to be done at 115200 aparently to work like in theory.
The main problem now is, that i cant now Use AT commands anymore
just dont do nothing, I tryed
AT
AT+WOPEN=0
AT+WOPEN=3
AT+WOPEN=4
AT+CFUN=1
Control+C
Control+V
Esc
Control+X
kill
die
end
also i tryed to unplugg it, disconnect it,
and just keep saying OK every 10 secs,
I readed here another posts with other kinds of modems that have the same problem and, a short with 1K resistor between pin3 and pin9 should hard reset the modem, but, where?
in the DB15 modems connector, or
in the DB9 Serial pc connected-to connector?
exist another way to hard reset the modem?
Thanks in Advance
Daniel.
Please can somebody confirm if the short pins are correct for hard reset the device?
Thanks,Daniel
Using the reset pin is no different to power-cycling the device.
What can I do? to turn off the uploaded program
can you tell me if my procedure is ok?
i mean for the gcc_Hello_World.wpb.dwl is that the one i should upload?
Thanks and sorry for my ignorance…
Usually you should use AT+WOPEN=1 to start an embedded application. Maybe that helps…
I put that and it says OK
but not like an answer, its more like the 10 seconds OK
for ex:
AT+WOPEN=1
OK (10 secs later)
OK (10 secs later)
OK (10 secs later)
OK (10 secs later)
OK (10 secs later)
seems that is not responding to any AT command
is there a magic way to turn off Open at application?
Thanks in Advanace.
Daniel
It’s not magic - it’s documented in the AT Commands guide:
AT+WOPEN=0 - Stop the Open-AT Application;
AT+WOPEN=1 - Start the Open-AT Application.
I know but in my case I do need some magic or something, because those commands doesnt work also any AT Command dont work, because of the OpenAt project running application
Any ideas i would be glad
Use DWL Win
