today for some reason, I was no longer getting any debug messages printed to the hypterterminal screen. So I reflashed the hello world application to the Q2687 dev board, and still no luck. I no longer get any responses from the board even when i try to issue any AT command.
I have also had this happen to me on the WMP100 devices. In my case I had to eventually reflash the OpenAT OS back on the the device.
But before you do that, make sure it is not just your hyperterminal or serial cable. Try restarting hyperterminal or your computer and see if that helps.
Another thing to try is to see at least if the device output the special control characters when you reboot it. You should be able to see these as two or three funny characters that come out of the serial port right after you roboot the device.
It is quite worrying that it sometimes go into such a state that the only way to recover is by reflashing the OpenAt. I’ve also had it happen to me on a few occations during an intensive development project. But until today I can not say for sure what caused it to go faulty and even how to reproduce it.
