I’m using Open AT ver. 3.02, and I want to try to download sample Hello World application into the modem, but it doesn’t work. I check the modem, it said “AT v2.0â€. Does this cause the error?
Hey man,
Try to send the command “a+wopen=2”, what is the response ???
What are u doing to download the firmware ?? What kind of error did ou receive ???
Ok. I also tried in remote mode. And it make error. This is the error :
Trace HWL 1 Arm exception 1 12c0a84 900 Trace HAC 1 Unable to find the string of the remote trace in the file (ID = 3013) Trace HAC 1 Unable to find the string of the remote trace in the file (ID = 3013) Trace HAC 1 Unable to find the string of the remote trace in the file (ID = 3013) Trace L3RR 1 Unable to find the string of the remote trace in the file (ID = 3449) Trace HWL 1 Arm exception 1 1340a98 900 Trace L3RR 1 Unable to find the string of the remote trace in the file (ID = 4366) Trace L3RR 1 Unable to find the string of the remote trace in the file (ID = 3449) Trace L3RR 1 Unable to find the string of the remote trace in the file (ID = 4142) Trace HWL 1 Arm exception 1 12c0a88 900
For information my modem has this information:
ATI3
641b09gg.Q2406E 1339080 041604 16:04
AT+WOPEN=2
+WOPEN: 2,“AT v02.10”
And I’m using Opent AT v.302, it only has this file on it \V302\Wavecom Core Software\X51\OtherCountries :
351__full_q2400a.dwl
351_w.dwl
651__full_q2406a.dwl
651__full_q2406b.dwl
651__full_q2426b.dwl
651__full_q2501b.dwl
651_w.dwl
gen.backtraces64k.axf
Does this make incompatibility and then create the error?
As far as I know you need to update the firmware.
Try to send the 651__full_qxxxx.dwl to the module.
Open the hyperterminal and send the commands:
at+wopen=0
at+wind=0
at+wopen=4
at+wdwl
-> After receveing $$$$$ send the file …and when it finished send the command at+cfun=1
You can check if it worked sending the command ati3 as you did before
Hi all
Here is a compatibility table
at+wopen=0
at+wind=0
at+wopen=4
ERROR
at+wdwl
(when I Download 651__full_qxxxx.dwl, error)
I follow another step:
*** ERROR IN FILE ***
aatt++ccffuunn==11
at
at
at+wopen=0
at+wind=0
at+wopen=4
ERROR
at+cmee=`1
ERROR
at+cmee=1
at+wopen=4
+CME ERROR: 532
at+at
ERROR
at
at+wdwl?
+WDWL: V02.06
at+wdwl
+WDWL: 0
aatt++ccffuunn==11
(I Download dwl.dwl)
at
at+wdwl?
+WDWL: V02.16
at+wopen=2
at+wopen=0
at+wind=0
at+wdwl
+WDWL: 0
$$$$$$$$$$$$$$$$$(I’m(
(I download w.dwl, after finished I download 652__full_q2406b.dwl without using at+cfun=1, after 11 retry atempt my modem hang)
at+cfun=1
at
at
at+cfun=1
at+cfun=1
at+
at
at
at+cfun=1
at+wdwl?
at
The red led is off.
I unplug the power and plug it again, but no respond.
Help please
What should i do.
Help please
Alfredo,
Try to reinstall the firmware using DWLWin.
You should ask you distributer for the software and firmware files !!!
Gus
My distributor give me the second step (read my post before this one) and three file :
- dwl.dwl 63.1 KB (64,690 bytes)
- w.dwl 2.13 KB (2,183 bytes)
- 652__full_q2406b.dwl 959 KB (982,056 bytes)
Where do I get DWLWin?
