HI,
I like to us the part XA1100 in one of our design. I need aconfirmation for the below querries
Is XA1100 support restart through AT commands
Is XA1100 support Power-On /Off through AT commands
In order to set XA1100 to output NMEA data at Baud rate of 115200 by default is it sufficient to pull down BR pin through a 10KOhm Resistor?
Rejeesh S Raj
Hi Rejeesh,
below feedback regarding your questions:
Restart through AT commands:
You could use various MTK NMEA commands to:
hot start - $PMTK10132
warm start - $PMTK10231
or cold start - $PMTK103*30
the GPS. You could also refer to the Software User Guide available from The Source for more details:
https://source.sierrawireless.com/resources/airprime/hardware_specs_user_guides/airprime---software-user-guide/ -
You can only put the GPS in sleep mode using MTK NMEA command - $PMTK161,0*28. Again refer to the Software User Guide for more details.
Yes, you could use a 10K resister to ground to select 115200 baud.
Regards,
Phillip
