for many years we bought the FXT009 series, but now is EOL and in Europe is very difficult to find
How we can replaces fxt009 with an equivalent model?
Thank you in avance
Thank you in avance
Frederico,
There is no directly replaceable part, the one that is closest to it is the FX30 although it depends on how you are using it as to how compatible this will be.
https://source.sierrawireless.com/devices/fx-series/fx30/
Hi Matt,
thank you for reply.
We use this modem connected via usb cable to pc, it is uesd for send automatic sms and connecting a modify rs232 cable with jack audio connected at sound card, we calls some phone numbers sending wave audio.
In reply we can receive dtmf replies for logging answer type.
We need ao a modem with the same specification and with sim card.
Thank you in advance.
Federico
Also the FX100 is EOL?
Frederico,
Yes the only product which is currently right now is either the FX30 or the GL series which, depending on what you want to do (obviously there are a load of other AirLink products which are current but I suspect given you previously used FXT009 these would be overkill).
