Some body share your ideas in interfacing Gps with Q2686 usb port
As you know the usb is slave in Q2686. if i connect my gps in usb port does the module can receives data ?
Correct.
So your GPS must have a Host (or, at least, OTG) USB port - right?
If your GPS can correctly “host” the modem then, of course, you can use the USB to communicate…
Hi awneil ,
Thanks for your reply. The gps we using dosen’t have host or otg. kindly suggest me the gps module which have Host or atleast otg
Thank you.
I have no idea - I’m afraid you’re going to have to do your own research on that one!
I wouldn’t have thought that they’re going to be very common, though - if they even exist at all…
I think your idea of using USB is basically flawed here.
most of them would be serial or even spi
Hiya,
Have you looked into the CGPS companion chipset that Wavecom supply & support?
There’s an IESM board for the Fastrack Supreme with it already set up.
ciao, Dave
Hi for my part, I need to load and reread certain data through the USB port. How I can do that? did there is any app note or sample (not found in M2M :’( …)
thanks for any help.
ON the PC, it appears as just another COM port;
On the module, it appears as just another Flow - see the [b]Flow Control Manager /b section (in the ADL User Guide) for details.
