Reading a Device from the API Docs
Here is what I did:
curl "https://octave-api.sierrawireless.io/v5.0/my_company/device/my_device_id" \
     -H 'X-Auth-Token: my_master_token' \
     -H 'X-Auth-User:  my_user_name'
The master token, company name, user_name were taken from the Master Token
on the left hand menu. The device id from the details section.
Here is what I got:
{“head”:{“status”:403,“ok”:false,“messages”:,“errors”:[“Access to the requested resource is forbidden. Invalid User or Token”],“references”:{}},“body”:{}}curl: (3) URL using bad/illegal format or missing URL
curl: (3) URL using bad/illegal format or missing URL.
Any ideas?
I tried the same kind of request on one of my devices and worked for me.
Here is the request (I just removed the token):
curl https://octave-api.sierrawireless.io/v5.0/iot_solutions/device/d5e3c68b6438bfa097e976132 -H “X-Auth-User: dla” -H “X-Auth-Token: xxx”
Thank You! I removed the single quotes from the url and used double quotes around
the -H parameters.
It Worked!!!
