Register a device on Octave is fairly easy and well documented. However, I could not find any document on removing device from Octave. Is this doable?
Hi James,
You can remove a device using API:
HTTP Request
DELETE https://octave-api.sierrawireless.io/v5.0/<company_name>/device/<device_identifier>
You can refer https://rest.octave.dev/#deleting-a-device
Thanks a lot for the info, David.
Albert’s device was moved to my company successfully yesterday. But since then, he can not access to his Octave account. The dashboard never show after login. Can you remove his account so he can register with his email again?
James
Hi James,
I removed him from both companies.
Thanks, David. I’ll invite him again and see if it works.
James
