API GET Request | Access to the requested resource is forbidden
when I am trying to integrate with the API, I am running in to some problems.
Both when i use CURL and get requests in python I get the following error:
{‘head’: {‘status’: 403, ‘ok’: False, ‘messages’: , ‘errors’: [‘Access to the requested resource is forbidden. Invalid User or Token’], ‘references’: {}}, ‘body’: {}}
My code looks like this (with XXXX and company_name filled out):
import requests
URL = “https://octave-api.sierrawireless.io/v5.0/<COMPANY_NAME>/device/?only=id,name”
user = ‘XXXX’
token = ‘XXXX’
PARAMS = {‘X-Auth-User’:user, ‘X-Auth-Token’: token}
r = requests.get(url = URL, params = PARAMS)
data = r.json()
print(data)
Hi @oliners
Please try with:
curl [https://octave-api.sierrawireless.io/v5.0/my_company/device/my_device_id] -H “X-Auth-User: xxx” -H “X-Auth-Token: xxx”
Help to tick “Solutions” if your question is answered.
Hi, thank you for your answer, but it is still not working for me.
I still get the following response : curl: (6) Could not resolve host
Do you knwo what this could be?
Hi @oliners
You are missing the device id parameter.
It works for me. I just hide sensitive information about user, token, company name and device ID.
import requests
url = “https://octave-api.sierrawireless.io/v5.0/COMPANY_NAME/device/DEVICE_ID/?only=id,name”
payload = {}
headers = {
‘X-Auth-User’: ‘xxx’,
‘X-Auth-Token’: ‘xxx’
response = requests.request(“GET”, url, headers=headers, data = payload)
print(response.text.encode(‘utf8’))
Please help to tick “Solutions” if your question is answered.
