Problem with Verizon SIM on EM7455
Hi Tomato, thanks for your reply. Here are the output for the commands you like me to run. These are run on the Sierra eval kit with a EM7455 module and a Verizon SIM. The problem I am having is that the module cannot connect to the network.
The same module works perfectly with a Tmobile and AT&T SIM card.
ati
Model: EM7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: 35907306139430
IMEI: 359073061394304
IMEI SV: 12
FSN: LF833224780210
+GCAP: +CGSM
at!impref?
!IMPREF:
preferred fw version: 02.24.05.06
preferred carrier name: GENERIC
preferred config name: GENERIC_002.026_000
current fw version: 02.24.05.06
current carrier name: GENERIC
current config name: GENERIC_002.026_000
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at!gstatus?
!GSTATUS:
Current Time: 13442 Temperature: 22
Reset Counter: 1 Mode: ONLINE
System mode: WCDMA PS state: Not attached
WCDMA band: WCDMA 850
WCDMA channel: 4385
GMM (PS) state:DEREGISTERED PLMN SEARCH
MM (CS) state: IDLE NO IMSI
WCDMA L1 state:L1M_PCH_SLEEP LAC: D8E7 (55527)
RRC state: DISCONNECTED Cell ID: 033B8F3F (54234943)
RxM RSSI C0: -94 RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
at!pcinfo?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
LPM persistence - None
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
SINGLEAPNSWITCH 0x01
