I try first with normal AT commands (not internet plugin AT commands), but I can’t connect, I get a NO CARRIER response.
After that i try to connect using WIP commands, but all commands responses ERROR. I have the Internet plugin enabled (I think). This is the log of all trying:
AT
AT+CMEE=1
AT+WOPEN=1
AT+WIPCFG?
ERROR
AT+WIPCFG=?
ERROR
AT+WOPEN?
+WOPEN: 1
There is no way to have it…
I try to make a
AT+WOPEN=3
AT+WOPEN=4
and then reload the “gcc_WIPSoft_256KB.wpd.dwl” file
after that wfun=1
wopen = 1
but nothing…
there are three dwl files in the same directory:
ads_WIPSoft_256KB.wpb.dwl
rvds_WIPSoft_256KB.wpd.dwl
I only send gcc_WIPSoft_256KB.wpd.dwl because I see in a post that this is the file needed. Is this the only needed file or I need to send the three files???
You are right, the problem was between the firmware version and plugin version. I update the firmware to the last version and now, I have WIP comands correctly:
