Hello everybody,
I have a Fastrack Supreme 20 and I’m working on an application, that sends SMS’s when a GPIO receives a pulse. I figured out how to make like a “AT ‘set’ command” that tells the program, to what cellphone number it has to send a SMS and with what text, depending on what GPIO is activated. The number of cellphones that can receive this SMS is up to 5 and the “AT Command” that I created was:
at+optoc = <cellphone 1-5> , , <Text for the GPIO 21> ,
It works great when I just set one cellphone but when I give this “AT Command” for the 2nd, 3rd, 4th or 5th cellphone… (I mean, when I set more than one cellphone) there are problems with the variables, that store the cellphone number and the text for the GPIO’s
Here is my code:
/* signal_generator.c - Copyright Wavecom S.A. (c) 2006 */
/* DISCLAIMER OF WARRANTY */
/* This Software is provided free of charge on an 'as is' basis. No warranty is given */
/* by Wavecom S.A. in relation to the Software of the uses to which it may be put by you, */
/* the user, or its merchantability, fitness or suitability for any particular purpose */
/* or conditions; and/or that the use of the Software and all documentation relating */
/* thereto by the Licensee will not infringe any third party copyright or other */
/* intellectual property rights. Wavecom S.A. shall furthermore be under no obligation */
/* to provide support of any nature for the Software and the Documentation. */
/* LIMIT OF LIABILITY */
/* In no event shall Wavecom S.A. be liable for any loss or damages whatsoever or howsoever */
/* caused arising directly or indirectly in connection with this licence, the Software, */
/* its use or otherwise except to the extent that such liability may not be lawfully */
/* excluded. Notwithstanding the generality of the foregoing, Wavecom S.A. expressly */
/* excludes liability for indirect, special, incidental or consequential loss or damage */
/* which may arise in respect of the Software or its use, or in respect of other equipment */
/* or property, or for loss of profit, business, revenue, goodwill or anticipated savings. */
/* File : signal_generator.c */
/* Scope : Signal Generator sample (TCU interrupt handling sample) */
#include "adl_global.h"
#define GPIO_INPUT1 25
#define GPIO_INPUT 21
// GPIO service handle
static s32 MyGPIOHandle_IN1;
static s32 MyGPIOHandle_IN;
s32 ReadValue;
s32 ReadValue1;
adl_ioDefs_t GpioConfig_IN1 = ADL_IO_GPIO | GPIO_INPUT1 | ADL_IO_DIR_IN;
adl_ioDefs_t GpioConfig_IN = ADL_IO_GPIO | GPIO_INPUT | ADL_IO_DIR_IN;
/* Mandatory variables (Call stack sizes) */
/* wm_apmCustomStackSize */
const u16 wm_apmCustomStackSize = 1024*3;
/* Local variables */
// Commands strings
static const ascii * AtCmdStr_OPTOC = "AT+OPTOC";
//Variables para el celular 1
ascii *num1, *texth1, *textl1;
bool cel1=FALSE;
//Variables para el celular 2
ascii *num2, *texth2, *textl2;
bool cel2=FALSE;
//Variables para el celular 3
ascii *num3, *texth3, *textl3;
bool cel3=FALSE;
//Variables para el celular 4
ascii *num4, *texth4, *textl4;
bool cel4=FALSE;
//Variables para el celular 5
ascii *num5, *texth5, *textl5;
bool cel5=FALSE;
//Variables para mensajes
s8 handle;
void SimHandler(u8 Event);
void SmsCtrlHandler( u8 Event, u16 Nb );
bool SmsHandler( ascii * SmsTel, ascii * SmsTimeOrLength, ascii * SmsText );
//MyMsg
//ascii *myMsg;
//GPIO's
s32 MyGpioEventHandle;
s32 MyGpioEventHandle1;
static s32 MyGPIOHandle_IN1 = ERROR;
static s32 MyGPIOHandle_IN = ERROR;
//Contadores
int counter1 = 1;
int counter2 = 1;
int conth = 0;
int contl = 0;
//Funciones
void celh1 (u8 Id);
void celh2 (u8 Id);
void celh3 (u8 Id);
void celh4 (u8 Id);
void celh5 (u8 Id);
void cell1 (u8 Id);
void cell2 (u8 Id);
void cell3 (u8 Id);
void cell4 (u8 Id);
void cell5 (u8 Id);
/* Local functions */
/* Function : MyControlCommandHandler */
/* Scope : AT+SIGNAL command handler */
/* Return : VOID */
/* Variable Name |IN |OUT| Use */
/* params | X | | Incoming AT command parameters */
static void MyControlCommandHandler ( adl_atCmdPreParser_t * params )
// Switch on command type
switch ( params->Type )
// Parameters command
case ADL_CMD_TYPE_PARA :
// Analyses parameters
ascii * P0 = ADL_GET_PARAM ( params, 0 ),
* P1 = ADL_GET_PARAM ( params, 1 ),
* P2 = ADL_GET_PARAM ( params, 2 ),
* P3 = ADL_GET_PARAM ( params, 3 );
u16 iP0;
//u32 iP1;
//char iP2; //iP3;
adl_atSendResponse(ADL_AT_RSP, "\r\n");
adl_atSendResponse(ADL_AT_RSP, "Celular: ");
adl_atSendResponse(ADL_AT_RSP, P0);
adl_atSendResponse(ADL_AT_RSP, "Numero: ");
adl_atSendResponse(ADL_AT_RSP, P1);
adl_atSendResponse(ADL_AT_RSP, "Mensaje Pera ARRIBA: ");
adl_atSendResponse(ADL_AT_RSP, P2);
adl_atSendResponse(ADL_AT_RSP, "Mensaje Pera ABAJO: ");
adl_atSendResponse(ADL_AT_RSP, P3);
adl_atSendResponse(ADL_AT_RSP, "\r\n---------------------------------\r\n");
if ((iP0 = wm_atoi ( P0 ))==1)
TRACE (( 1, "Celular 1 definido" ));
adl_atSendResponse(ADL_AT_RSP, "OK");
num1=P1;
texth1=P2;
textl1=P3;
cel1=TRUE;
adl_atSendResponse(ADL_AT_RSP, num1);
adl_atSendResponse(ADL_AT_RSP, texth1);
adl_atSendResponse(ADL_AT_RSP, textl1);
if ((iP0 = wm_atoi ( P0 ))==2)
TRACE (( 1, "Celular 2 definido" ));
num2=P1;
texth2=P2;
textl2=P3;
cel2=TRUE;
adl_atSendResponse(ADL_AT_RSP, num2);
adl_atSendResponse(ADL_AT_RSP, texth2);
adl_atSendResponse(ADL_AT_RSP, textl2);
if ((iP0 = wm_atoi ( P0 ))==3)
TRACE (( 1, "Celular 3 definido" ));
num3=P1;
texth3=P2;
textl3=P3;
cel3=TRUE;
adl_atSendResponse(ADL_AT_RSP, num3);
adl_atSendResponse(ADL_AT_RSP, texth3);
adl_atSendResponse(ADL_AT_RSP, textl3);
if ((iP0 = wm_atoi ( P0 ))==4)
TRACE (( 1, "Celular 4 definido" ));
num4=P1;
texth4=P2;
textl4=P3;
cel4=TRUE;
adl_atSendResponse(ADL_AT_RSP, num4);
adl_atSendResponse(ADL_AT_RSP, texth4);
adl_atSendResponse(ADL_AT_RSP, textl4);
if ((iP0 = wm_atoi ( P0 ))==5)
TRACE (( 1, "Celular 5 definido" ));
num5=P1;
texth5=P2;
textl5=P3;
cel5=TRUE;
adl_atSendResponse(ADL_AT_RSP, num5);
adl_atSendResponse(ADL_AT_RSP, texth5);
adl_atSendResponse(ADL_AT_RSP, textl5);
//Entrada 21: Pera de nivel que se encuentra ARRIBA
void MyGpioEventHandler ( s32 GpioHandle, adl_ioEvent_e Event, u32 Size, void * Param )
TRACE (( 1, "EVENT" ));
// Check event
switch ( Event )
case ADL_IO_EVENT_INPUT_CHANGED :
adl_atSendResponse(ADL_AT_RSP, "\r\nEntrada 21");
if ( counter1 % 2 == 0)
TRACE (( 1, "Mandando SMS E21" ));
if (cel1==TRUE)
adl_tmrSubscribe ( FALSE, 1, ADL_TMR_TYPE_100MS, celh1);
if (cel2==TRUE)
adl_tmrSubscribe ( FALSE, 71, ADL_TMR_TYPE_100MS, celh2);
if (cel3==TRUE)
adl_tmrSubscribe ( FALSE, 141, ADL_TMR_TYPE_100MS, celh3);
if (cel4==TRUE)
adl_tmrSubscribe ( FALSE, 211, ADL_TMR_TYPE_100MS, celh4);
if (cel5==TRUE)
adl_tmrSubscribe ( FALSE, 281, ADL_TMR_TYPE_100MS, celh5);
counter1 ++;
//Entrada 25: Pera de nivel que se encuentra ABAJO
void MyGpioEventHandler1 ( s32 GpioHandle, adl_ioEvent_e Event, u32 Size, void * Param )
// Check event
switch ( Event )
adl_atSendResponse(ADL_AT_RSP, "\r\nEntrada 25");
if ( counter2 % 2 == 0)
TRACE (( 1, "Mandando SMS E25" ));
if (cel1==TRUE)
adl_tmrSubscribe ( FALSE, 1, ADL_TMR_TYPE_100MS, cell1);
if (cel2==TRUE)
adl_tmrSubscribe ( FALSE, 71, ADL_TMR_TYPE_100MS, cell2);
if (cel3==TRUE)
adl_tmrSubscribe ( FALSE, 141, ADL_TMR_TYPE_100MS, cell3);
if (cel4==TRUE)
adl_tmrSubscribe ( FALSE, 211, ADL_TMR_TYPE_100MS, cell4);
if (cel5==TRUE)
adl_tmrSubscribe ( FALSE, 281, ADL_TMR_TYPE_100MS, cell5);
counter2 ++;
void celh1 (u8 Id)
ascii *myMsg1;
myMsg1 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg1[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg1, "%s", texth1);
adl_atSendResponse(ADL_AT_RSP,"\r\n");
adl_atSendResponse(ADL_AT_RSP, myMsg1);
adl_smsSend( handle, num1 , myMsg1, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg1);
void celh2 (u8 Id)
ascii *myMsg2;
myMsg2 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg2[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg2, "%s", texth2);
adl_atSendResponse(ADL_AT_RSP, myMsg2);
adl_smsSend( handle, num2 , myMsg2, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg2);
void celh3 (u8 Id)
ascii *myMsg3;
myMsg3 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg3[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg3, "%s", texth3);
adl_atSendResponse(ADL_AT_RSP, myMsg3);
adl_smsSend( handle, num3 , myMsg3, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg3);
void celh4 (u8 Id)
ascii *myMsg4;
myMsg4 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg4[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg4, "%s", texth4);
adl_atSendResponse(ADL_AT_RSP, myMsg4);
adl_smsSend( handle, num4 , myMsg4, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg4);
void celh5 (u8 Id)
ascii *myMsg5;
myMsg5 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg5[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg5, "%s", texth5);
adl_atSendResponse(ADL_AT_RSP, myMsg5);
adl_smsSend( handle, num5 , myMsg5, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg5);
void cell1 (u8 Id)
ascii *myMsg6;
myMsg6 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg6[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg6, "%s", textl1);
adl_atSendResponse(ADL_AT_RSP, myMsg6);
adl_smsSend( handle, num1 , myMsg6, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg6);
void cell2 (u8 Id)
ascii *myMsg7;
myMsg7 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg7[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg7, "%s", textl2);
adl_atSendResponse(ADL_AT_RSP, myMsg7);
adl_smsSend( handle, num2 , myMsg7, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg7);
void cell3 (u8 Id)
ascii *myMsg8;
myMsg8 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg8[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg8, "%s", textl3);
adl_atSendResponse(ADL_AT_RSP, myMsg8);
adl_smsSend( handle, num3 , myMsg8, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg8);
void cell4 (u8 Id)
ascii *myMsg9;
myMsg9 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg9[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg9, "%s", textl4);
adl_atSendResponse(ADL_AT_RSP, myMsg9);
adl_smsSend( handle, num4 , myMsg9, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg9);
void cell5 (u8 Id)
ascii *myMsg0;
myMsg0 = adl_memGet(sizeof(ascii)*128); // allocate memory for string
myMsg0[0] = 0x00; // ensure string starts with 'NUL'
wm_sprintf(myMsg0, "%s", textl5);
adl_atSendResponse(ADL_AT_RSP, myMsg0);
adl_smsSend( handle, num5 , myMsg0, ADL_SMS_MODE_TEXT );
adl_memRelease(myMsg0);
TRACE((1, " In Sim Handler"));
switch(Event)
case ADL_SIM_EVENT_REMOVED:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_REMOVED");
break;
case ADL_SIM_EVENT_INSERTED:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_INSERTED");
break;
case ADL_SIM_EVENT_FULL_INIT:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_FULL_INIT");
break;
case ADL_SIM_EVENT_PIN_ERROR:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_PIN_ERROR");
break;
case ADL_SIM_EVENT_PIN_OK:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_PIN_OK");
break;
case ADL_SIM_EVENT_PIN_WAIT:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_PIN_WAIT");
break;
case ADL_SIM_EVENT_PUK_WAIT:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_PUK_WAIT");
break;
case ADL_SIM_EVENT_PUK_ERROR:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_PUK_ERROR");
break;
case ADL_SIM_EVENT_FAILURE:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_FAILURE");
break;
case ADL_SIM_EVENT_NET_LOCK:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SIM_EVENT_NET_LOCK");
break;
TRACE((1, " IN SMS Ctrl handler"));
switch(Event)
case ADL_SMS_EVENT_SENDING_OK:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SMS_EVENT_SENDING_OK");
break;
case ADL_SMS_EVENT_SENDING_ERROR:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SMS_EVENT_SENDING_ERROR");
break;
case ADL_SMS_EVENT_SENDING_MR:
adl_atSendResponse(ADL_AT_RSP, "\r\nADL_SMS_EVENT_SENDING_MR");
break;
TRACE((1, " IN SMS data handler"));
adl_atSendResponse(ADL_AT_RSP, "\r\nSMS Phone Number: ");
adl_atSendResponse(ADL_AT_RSP, SmsTel);
adl_atSendResponse(ADL_AT_RSP, "\r\nSMS Time: ");
adl_atSendResponse(ADL_AT_RSP, SmsTimeOrLength);
adl_atSendResponse(ADL_AT_RSP, "\r\nSMS Text: ");
adl_atSendResponse(ADL_AT_RSP, SmsText);
return TRUE;
/* Function : adl_main */
/* Scope : Customer application initialisation */
/* InitType | X | | Application start mode reason */
TRACE (( 1, "Visual sample: Main" ));
// Subscribe to the control command
adl_atCmdSubscribe ( (ascii*) AtCmdStr_OPTOC, MyControlCommandHandler, ADL_CMD_TYPE_PARA | 0x41 );
// Subscribe the SIM
adl_simSubscribe ((adl_simHdlr_f)SimHandler, NULL);
handle = adl_smsSubscribe((adl_smsHdlr_f)SmsHandler, (adl_smsCtrlHdlr_f)SmsCtrlHandler, ADL_SMS_MODE_TEXT );
// set up and connect to GPIO
MyGpioEventHandle = adl_ioEventSubscribe (MyGpioEventHandler);
MyGpioEventHandle1 = adl_ioEventSubscribe (MyGpioEventHandler1);
MyGPIOHandle_IN = adl_ioSubscribe ( 1, &GpioConfig_IN, 1, 1, MyGpioEventHandle );
TRACE (( 1, "GPIO_IN handle: %d", MyGPIOHandle_IN ));
MyGPIOHandle_IN1 = adl_ioSubscribe ( 1, &GpioConfig_IN1, 1, 1, MyGpioEventHandle1 );
TRACE (( 1, "GPIO_IN1 handle: %d", MyGPIOHandle_IN1 ));
// operate on GPIO
adl_ioWriteSingle ( MyGPIOHandle_IN1, &GpioConfig_IN1, TRUE );
adl_ioWriteSingle ( MyGPIOHandle_IN, &GpioConfig_IN, TRUE );
ReadValue = adl_ioReadSingle (MyGPIOHandle_IN, &GpioConfig_IN);
TRACE (( 1, "PIN IN : %d",ReadValue ));
ReadValue1 = adl_ioReadSingle (MyGPIOHandle_IN1, &GpioConfig_IN1);
TRACE (( 1, "PIN IN : %d",ReadValue1 ));
//TRACE (( 1, "GPIO (%d): %d", GPIO_OUTPUT_PIN, &GpioConfig_OUT ));
//TRACE (( 1, "GPIO (%d): %d", GPIO_INPUT_PIN, &GpioConfig_OUT ));
Can anyone please help me?? I really don’t have any idea, why this problem is happening… Please help me with this
All answers would be very much apreciated!!
Thanks!!
Pd.- Sorry if there are some phrases in the programm in spanish, but I was a little bit lazy to change them… so just focus on the code :mrgreen:
