Q24 Auto SMS messaging using AT comamnd in C program
I want to send out SMS messaging using AT command in a C program. The program is tested working on SIMCOM module, but it failed to send out SMS from WaveCOM Q24 automotive module.
I tried to similate the problem using Hyperterminal or minicom. The Wavecom Q24 module always return “Error” reply when I input the AT+CMGS command in one complete line. Can anyone help me on this problem?
AT+CMGF=1
AT+CMGS=“xxxxxxxx”\r"TEST"\x1A
ERROR
The C program:
char buffer[256];
char *phone_number=“xxxxxxx”;
sprintf(buffer,“AT+CMGS=”%s"\rabc%c", phone_number, 26);
write(fd, buffer, strlen(buffer));
Does anybody solve this problem before?
Thank you.
Regards,
TS
You need to wait for the “>” prompt before you send the message content!
Thank you.
We are also having this problem. Our difference is that we are using the Terminal Emulator from the Target Monitoring Tool.
Whenever we type
at+cmgs="+19795400744"
we see
ERROR
Does anyone know what the problem is here??
first you should type at command
AT+CMGF=1
If you wanmt to know what is tha error just activate error display by giving command “AT+CMEE=1” after this try to send the SMS you get ERROR: with number By using that number you can solve the problem you are facing.
If you want to know what is that error,
Try and reply the answer…
