I use Basic API because I thought it was easier and I have spent a lot of time to change now.
I looked at the at the samples and i found something.
Hmm… yes, the name is a bit unfortunate, isn’t it?
“Basic” could easily imply that it’s the “easy” option for making “basic” applications.
In fact, as far as I can tell, “Basic” means that the facilities provided are only basic - so that the developer has to do a lot more work.
ADL actually makes it a lot “easier” for the application developer.
Maybe this has just lost something in translation from the original French…? (which is not uncommon in the Wavecom documents )
In this case, though, the Wavecom documents do clearly state that ADL is the one to use unless you really know what you’re doing.
