I need some help, i try to make the Fastrack supreme 20 sending an sms right after we inject the supply voltage so we’re working on a program in C, but we have some problems with the line:
adl_atCmdSendText( ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), “solde”);
the other ones work the terminal shows OK when we test it but it stops with the adl_atCmdSendText i dont know why…
Well maybe this program will never work for what im trying to do cause it’s totally different than the SMS_automation from the samples in OPEN_AT so i’d be glad if someone could help me with that or giving me some samples or anything.
Thank you.
#include "adl_global.h"
/* Mandatory variables */
/* wm_apmCustomStackSize */
const u16 wm_apmCustomStackSize = 1024;
/* Local variables */
/* Local functions */
/* Function : adl_main */
/* Object : Customer application initialisation */
/* Variable Name |IN |OUT|GLB| Utilisation */
/* InitType | | | | Application start mode reason */
/*s16 Cmgs_Handler(adl_atResponse_t *paras)
adl_atCmdSendText( ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), "repond stp c pour un test");
void test ( u8 ID )
adl_atSendResponse ( ADL_AT_UNS, "\r\nSend SMS\r\n" );
//adl_atCmdCreate("AT+CNMI=0,1,1,1,0", ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), (adl_atRspHandler_t)NULL, NULL);
adl_atCmdCreate("AT+CSMP=17,169,0,0", ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), (adl_atRspHandler_t)NULL, NULL);
adl_atCmdCreate("AT+CMGF=1", ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), (adl_atRspHandler_t)NULL, NULL);
adl_atCmdCreate("AT+csca=0609001390", ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), (adl_atRspHandler_t)NULL, NULL);
adl_atCmdCreate("AT+CMGS=950", ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), (adl_atRspHandler_t)NULL, NULL);
adl_atCmdSendText( ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), "solde");
TRACE (( 1, "Embedded Application : Send_Sms" ));
// TO DO : Add your initialization code here
adl_tmrSubscribe ( FALSE, 35, ADL_TMR_TYPE_100MS, test );
//adl_atCmdCreate("AT+CMGS=0629747477", ADL_AT_PORT_TYPE(ADL_PORT_UART1, TRUE), (adl_atRspHandler_t)Cmgs_Handler, ">", NULL);
