Open AT
Hi Everyone,
Please, help with what function in the “Open AT” I can check the TCP connection client to the server. And what function resets the modem.
hi
you can reset your modem with the “at+cfun=1” command. check the adl_atCmdCreate() function in the manual.
edit:
i didnt look it up, but if i remember correctly there isnt a direct way which allows you to reset the modul, so you have to go this way.
For me, this area is new and I do not fully understand how to write programs, and whether you can append to the end of the existing program’s. I need to finish a small algorithm. It looks like this: check for client communication with the server if the connection is missing, then reconnect after 10 minutes, and if the connection okay, then after 10 minutes, check its status again.
hi
with “not fully understand how to write programs” do you mean that you have no experience writing programs at all or do you mean, that you dont have a clue where to start in OpenAt?
Yes, I mean, that I dont have a clue where to start in OpenAt!
okay, thats a relief :laughing:
do you have the dev studio installed and can you connect to your device?
if so, you should thrown an eye onto the “ADL_User_Guide.pdf” Chapter 2.
This document includes a couple of examples for the different basic APIs that are implemented.
If you want to call a server via IP, you also want to throw an eye into the “WIP_Open_AT_IP_Connectivity_Development_Guide.pdf”, it has everything from sockets to FTP.
Also the dev studio has a couple of example projects. you can find them at the creation of a new Open At project.
edit:
you can find those PDF files somewhere inside the install directory of your dev studio. use the search function and search for .pdf files.
Some specialist helped me to make the client and server. Now I need to add in listing some algorithm that will monitor the connection and make rekonekt. I’m trying to implement it as follows:
PingRet=wip_pingCreate (SERVER_ADDRESS, WIP_CEV_PING,1);
error:Multiple markers at this line
- passing argument 2 of ‘wip_pingCreate’ makes pointer from integer without a cast
- assignment makes integer from pointer without a cast
- passing argument 3 of ‘wip_pingCreate’ makes pointer from integer without a cast
PingRet1=wip_pingCreateOpts(SERVER_ADDRESS,WIP_COPT_INTERVAL,60000);
- passing argument 2 of ‘wip_pingCreateOpts’ makes pointer from integer without a cast
- passing argument 3 of ‘wip_pingCreateOpts’ makes pointer from integer without a cast
if (PingRet==0){adl_wdActiveAppWd(1);}
But I have error at 1st and 2nd line. Can you tell what I wrote is not correct.
my guess is, that the vars you are putting into the function aren´t from the type the function expects…
check the wip dev guide to see what types the functions are expecting
edit:
im not sure what happens if you name your function like a value from an enum, but i´d change the name
I tried to change the variable type, and experimenting with the parameters used functions but still no result.
and what have you tried?
and another thing that just came into my head…
does the server even answer ping requests? it might be deactivated… :smiley:
i guess the client isn´t a system where you have the controll? otherwise i would let the client make whatsoever out of the information that his requests are getting timeouts
The server pinged with windows!
The client connects to it and creates an open channel of communication. But I need so that in case of loss of communication, the client can reconnect.
why cant the client just reconnect when an error occurs?
Because the program that was wrote for me does not provide it.
do you have the source code?
if so, make that it simply reconnects :smiley:
if not, how do you want to tell the program that it has to reconnect?
Therefore it is necessary to write a piece of code that will monitor and make reconnect.
If you can, then write the code.
I will be grateful.
