The actual file names may differ slightly for different versions of the SDK, but:
For WIP specifically, you will need to study the “Open-AT IP Connectivity Development Guide (WIPlib v4.00)”, WIP_Open_AT_IP_Connectivity_Development_Guide_V4_00.pdf
And, of course, for doing anything over the Internet (or other IP-based networks) you will need a working understanding of how IP-based networks work, internet protocols, etc…
Everything fine until page 21: “In the Remote Application Controller”.
When I press the “start” button a “Server Busy” pop up window appears:
“This action cannot be completed because the other program is busy. Choose ‘Switch To’ activate the busy program and correct the problem”.
What should I do?
Could you give me a further explanation about which application is acting as a server, and which application is acting as a client, who are the other possible clients making the server busy, or which are the resource locks that could block the server?
May you please shed light on how to establish a TCP/IP connection using the Q2687 modem. I am not really understanding the TCP/IP example on the SDK. I need to get a general overview of how to start writing code to establish a TCP/IP connection and how to use run this on terminal emulator or target monitoring too.
