Octave vs airplane mode
Hi
What is Octaves expected behaviour when it encounters from the cellular interface / radio
  1. An unexpected change to “airplane mode” (e.g. radio low voltage, high temperature …)
  2. A requested change to “airplane mode” (e.g. cm radio off , api call to radio off …)
Many thanks
John
Hi John, What device are you asking about?
Hi David
Good point
As far as I know - Octaves handling of Airplane mode is common to all of the current Octave devices as Airplane mode is a function of the WP7702 module - which is common to all the current Octave devices
  • WP7702
  • FX30S
  • mangOH red
  • mangOH yellow
Cheers
John
Hi John,
Currently, there are no resources defined in Octave to monitor or control airplane mode for any of the Octave enabled devices. Ultra Low Power Mode (ULPM) can be configured in Octave. To effectively work with ULPM on the FX30, I would wait for Firmware version 2.1.4.
Hi David
Thanks for the feedback - a public or accessible bug list would be very helpful with this sort of thing as we’re just discovering the already discovered.
I think there could be an issue with some mangOH yellow boards regarding airplane mode which has highlighted Octaves inability to handle this edge use case. We have eliminated the mangOH power source as the cause.
The problem is we are also experiencing the unrelated network registration issue at the same time which was making diag really difficult. I’m hoping the network registration workaround should help us focus purely on the airplane mode issue from now on
Cheers
John
Hi John, referring to your initial question, when module radio goes off Octave will not try to activate it back, so your app has to handle that case. In this situation, if Octave has some data to send to the cloud they will be stored in the “store and forward” memory which will be flushed the next time the module will be connected.
Hope this helps.
Didier
Hi Didier
That’s a tricky one - is it now possible for developers to build Octave enabled Legato systems?
Cheers
John
