I have spent some time on configuring a MangOH yellow using the available documents and have so far managed to cover several features: combining sensor readings into a single update to cloud, periodic updates, storing state in virtual resources and so on. The configuration uses ultra low power mode to sleep and wake periodically to provide sensor readings while maximising battery life.
The problem I have is that this is not reliable. While octave is in charge it seems the sleep is not always honoured resulting in power draining behaviour. Also there are times when the device stops reporting for no apparent reason, for days at a time. Power cycling, connecting debug cables or resetting will usually bring it back to life.
How can I diagnose this behaviour or take steps to ensure the system is more reliable?
