Hi
With the following kit
HW mangOH yellow
FW 3.0.0-pre23April2020-mangOH-0
Applying a Blueprint copied from a system which had the io/config set to configure UART1 didn’t apply the UART1 setting when deployed in a different companies edge device
The blueprint contains the following
Device is
Thanks is advance
John
Looking back at the log - I could see that the blueprint deploy operation had failed.
But the Octave web UI indicated that the blueprint was deployed.
Applying the blueprint a second time fixed the issue.
Hi John,
Was the blueprint source device and target device the same model and on the same firmware?
Yes same device and FW
I think the problem was that the power failed part way through - the backend abandoned the update I think
Hi John, I will replicate and issue an engineering ticket. I will let you know my results
