I kept getting the following error message when I tried to save bookmark or doing FOTA on Octave. This happened on one FX30S on the field. Anyone know what is the cause and how can I solve this issue?
Hi
your device embeds 3.3.1 and the blueprint that you tried to push has a length greater than 100kB (107340 bytes)
On 3.3.1, the maximum size of a blueprint is 100 kB, else such error is returned by the edge.
Octave supports a maximum Blueprint data size of 100,000 characters including comments and line feeds/carriage returns.
Thanks, Frederic.
I can successfully save blueprint after removing some EA.
However, is there any way to check the size of the blueprint so user will know if it is over the limit?
