you can see here:
How to install it into VS code? i mean looking for the instruction to install from git.
Instead, I am following this
https://docs.legato.io/15_10/basic_apps_create.html
I am at 5) and getting an error
Did you see here about the new application?
yes i have followed and got this without adef and cdef files
Did you install a sdk in the leaf icon?
How about type “leaf shell” inside the terminal of vscode and compile the app by “mkapp”
Why does it use localhost?
Have you tried linux pc?
I don’t know why it uses a local host. No, I did not try with a separate Linux PC. I have used an Ubuntu app in Windows and have done this as above.
If I provide TeamViewer login info, can sierra wireless provide me support to install everything where I can start creating apps?
It has taken long time only to set up the system before going to the main app’s build, which is not professional in my sense. If I used developer studio, it takes only a few minutes to do the setup. Please give me support. Thanks.
you use the wrong command:
(lsh:swi-wp76_4.7.0) owner@ubuntu:~/leaf/apps$ mkapp hello.adef
** ERROR:
Bad configuration environment file path '/home/owner/leaf/leaf-data/swi-wp76_4.7.0/wp76-legato/build/localhost/config.sh'.
(lsh:swi-wp76_4.7.0) owner@ubuntu:~/leaf/apps$ ls
c++ Demo hello.adef helloWorld.adef
(lsh:swi-wp76_4.7.0) owner@ubuntu:~/leaf/apps$ mkapp ${LEGATO_DEF_FILE} -s components -t ${LEGATO_TARGET} -w ${LEGATO_OBJECT_DIR} -o ${LEGATO_OUTPUT_DIR}
** WARNING: File system size limit being ignored for unsandboxed application 'hello1'.
[9/9] Packaging app
(lsh:swi-wp76_4.7.0) owner@ubuntu:~/leaf/apps$ export | grep LEGATO
declare -x LEGATO_CONFIG_SCRIPT="/home/owner/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/config.sh"
declare -x LEGATO_DEF_FILE="/home/owner/leaf/apps/Demo/hello1/hello1.adef"
declare -x LEGATO_LANGUAGE_SERVER="/home/owner/leaf/leaf-data/swi-wp76_4.7.0/swi-vscode-support/languageServer/languageServer.js"
declare -x LEGATO_OBJECT_DIR="./_build_hello1/wp76xx"
declare -x LEGATO_OUTPUT_DIR="."
declare -x LEGATO_ROOT="/home/owner/leaf/leaf-data/swi-wp76_4.7.0/wp76-legato"
declare -x LEGATO_SNIPPETS=":/home/owner/leaf/leaf-data/swi-wp76_4.7.0/swi-vscode-support/snippets"
declare -x LEGATO_SYSROOT="/home/owner/leaf/leaf-data/swi-wp76_4.7.0/wp76-toolchain/sysroots/armv7a-neon-poky-linux-gnueabi"
declare -x LEGATO_TARGET="wp76xx"
declare -x LEGATO_TOOLCHAIN_FULL_PREFIX="/home/owner/leaf/leaf-data/swi-wp76_4.7.0/wp76-toolchain/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-"
declare -x LEGATO_UPDATE_FILE="./hello1.wp76xx.update"
declare -x WP76XX_LEGATO_IMAGES="/home/owner/leaf/leaf-data/swi-wp76_4.7.0/wp76-legato-image"
(lsh:Test) shah@DESKTOP-OL21EQR:~$ mkapp ${LEGATO_DEF_FILE} -s components -t ${LEGATO_TARGET} -w ${LEGATO_OBJECT_DIR} -o ${LEGATO_OUTPUT_DIR}
[9/9] Packaging app
(lsh:Test) shah@DESKTOP-OL21EQR:~$ export | grep LEGATO
declare -x LEGATO_CONFIG_SCRIPT=“/home/shah/.leaf/wp77-legato_19.11.6-202112100804/build/wp77xx/config.sh”
declare -x LEGATO_DEBUG_DIR=“.debug”
declare -x LEGATO_DEF_FILE=“/home/shah/apps/hello_shah.adef”
declare -x LEGATO_DEV_MODE_ENABLE=“1”
declare -x LEGATO_LANGUAGE_SERVER=“/home/shah/leaf-data/Test/swi-vscode-support/languageServer/languageServer.js”
declare -x LEGATO_OBJECT_DIR=“./_build_hello_shah/wp77xx”
declare -x LEGATO_OUTPUT_DIR=“.”
declare -x LEGATO_ROOT=“/home/shah/leaf-data/Test/wp77-legato”
declare -x LEGATO_SNIPPETS=“:/home/shah/leaf-data/Test/swi-vscode-support/snippets”
declare -x LEGATO_SYSROOT=“/home/shah/leaf-data/Test/wp77-toolchain/sysroots/armv7a-neon-poky-linux-gnueabi”
declare -x LEGATO_TARGET=“wp77xx”
declare -x LEGATO_TOOLCHAIN_FULL_PREFIX=“/home/shah/leaf-data/Test/wp77-toolchain/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-”
declare -x LEGATO_UPDATE_FILE=“./hello_shah.wp77xx.update”
declare -x WP77XX_LEGATO_IMAGES=“/home/shah/leaf-data/Test/wp77-legato-image”
(lsh:Test) shah@DESKTOP-OL21EQR:~$ ls
Mysystem_test.sdef _build_Mysytemnew components leaf-data
Mysytemnew.sdef _build_hello_shah helloComp leaf-workspace.json
Mysytemnew.wp77xx.update apps hello_shah.wp77xx.update mangOH
(lsh:Test) shah@DESKTOP-OL21EQR:~$ cd helloComp/
(lsh:Test) shah@DESKTOP-OL21EQR:~/helloComp$ ls
Component.cdef hello.c helloworld.adef
(lsh:Test) shah@DESKTOP-OL21EQR:~/helloComp$ mkapp helloworld.adef
** ERROR:
Bad configuration environment file path ‘/home/shah/leaf-data/Test/wp77-legato/build/localhost/config.sh’.
Then it can compile successfully
I think i have got the way where i have to debug as like this. It works.
Yes, I can create an app now. However, seems complicated but let’s try with the main apps where I have to deal with GPS.
Can you check with an app where GPS is working or not?
You can use the gnss command
Did you check “AT!GPSSATINFO?” ?
You might also need to check the following AT commands to see if it can get GPS fix:
AT!ENTERCND=“A710”
AT!GPSEND=0
AT!GPSSATINFO?
AT!GPSFIX=1,255,1000
AT!GPSSTATUS?
AT!GPSLOC?
