I’ve been trying to get 14.10 working on my WP7100 with the red dev-kit. After the upgrade, I haven’t been able to connect to the cellular network.
Observations:
- Running ati returns a correct value. Running at!gstatus? shows me as being in low power mode.
- The command at!unlock=“A710” returns ERROR; therefore, I am unable to run at!gobiimdisabled=1 to change to ONLINE.
- Using the cm utility:
[code]root@swi-mdm9x15:~# cm sim
SIM card is inserted and unlocked (LE_SIM_READY).
root@swi-mdm9x15:~# cm radio
Current Network Operator:
Status: Not registered and not currently searching for new operator (LE_MRC_REG_NONE)
Signal: No signal strength (0)
root@swi-mdm9x15:~# cm radio on
root@swi-mdm9x15:~# cm radio off
Radio power is already set to OFF.[/code]
- The Ethernet port no longer works
- Running [i]at!custom?[\i] returns:
!CUSTOM:
ISVOICEN 0x01
CMCLIENT 0x01
ADBENABLE 0x01
GPSENABLE 0x01
RRCREL7CAPDIS 0x02
GPSSEL 0x01
NMEAENABLE 0x01
GOBIIMEN 0x01
- Probably unrelated, but the SD Card is also non-functional.
I’ve noticed a couple of people in the forums have had similar problems in the past, but none of their solutions have worked for me. Any help would be appreciated!
– Kevin
